Old 05-17-2008, 11:55 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
Tip: How to find stuff in the Studio
A great tool for finding where something on the screen corresponds to its location in the Studio is the 'UI Components' inspector.
Go to Debug->UI Components
Then that'll show you a tree of the memory model of the user interface on screen. And if you just follow the yellow box and keep navigating down the hierarchy; you'll always be able to find the component you're looking for. Then just right-click on it and you can then select to highlight the widget in the main Studio view (and if it's been themed you can select to highlight the themed source so you don't need to hunt for what's overriding how its being displayed)
(one thing to note is that it doesn't do the yellow highlight box for shape widgets; so those can be trickier to find on some occassions; but you'll at least be able to narrow it down significantly)
This is exactly what I do when I'm faced with the question of 'Where in the Studio is this thing I'm seeing on the screen?'
Hope that helps.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 06-19-2008, 09:20 AM
CollinR CollinR is offline
TY thats been half my problems in learning, thinking you found what you looking for but not quite.
Where to find SageTV logs? sjgore SageTV Beta Test Software 3 03-09-2007 03:25 PM
Studio Capabilites mayamaniac SageTV Studio 12 04-09-2006 02:47 PM
License Question Studio versus SageTV owilsky SageTV Studio 9 03-03-2006 08:21 PM
Using Studio with the trial version? jbuszkie SageTV Studio 4 12-02-2005 02:20 PM
Making COM interface calls with Studio? davin SageTV Studio 3 11-06-2005 07:32 PM
