Old 03-28-2009, 09:21 PM
KipKasper's Avatar
KipKasper KipKasper is offline
CPU Load
Hi all,
I have for a past few days had a strange new problem;
I run SageTV in service mode
after about a day of uptime the service will run at 100% CPU load. It has done this while in use and with the MVP turned off.
My server has always been up to the challenge till now
P4 2Ghz, Win2k-Server, PVR-150 PVR-500 6.4.8.184
Add-ons
Comskip
Custom Menus
EDIT:
I also have this server set to reboot every Sunday, just to take care of any memory leeks and what-not
Old 03-29-2009, 03:52 AM
davephan's Avatar
davephan davephan is offline
What are the top CPU processes when clicking on the "CPU" tab in "Windows Task Manager"? Are any of the processes sustained at or near 100%? You can get to "Windows Task Manager" by hitting 'Control', 'Shift', 'Escape".
Dave
Extenders: 1-HD-300, 2-HD-200
Old 03-29-2009, 01:17 PM
KipKasper's Avatar
Dave
Yes, the SageTvService is the top process
the transcoder is not even running when I've had this problem
Old 03-30-2009, 10:34 PM
KipKasper's Avatar
Possible Solution
I started thinking this was a corrupt Win.biz file, but when i started looking around I found that windows had filled the system drive to within 12k of capacity with log files
I have deleted all 26gigs of them and set up a scheduled batch file to keep it clear from now on
I am waiting to see if the system behaves now.
- Greg
Get a load of this: lobosrul The SageTV Community 1 08-03-2007 03:02 PM
CPU Utilization w/ HD Content: New CPU Needed? geogecko Hardware Support 18 07-23-2006 01:03 AM
This might be a dumb question but: Quality & CPU Load? judoGTI SageTV Software 2 05-16-2005 11:38 AM
High CPU load, corrupt wiz.bin file feared with 1.4.7 bling_bling_vr6 SageTV Beta Test Software 3 08-14-2003 12:42 PM
Won't Load justlearnin SageTV Beta Test Software 3 08-13-2003 12:56 PM
