Old 09-04-2009, 09:10 AM
Ikarius's Avatar
Ikarius Ikarius is offline
Tables and animation
Hey folks,
I'm attempting to use a table and do a fixed-focus navigation model.
Unfortunately, when I use EnsureVisibilityForVariable and SetFocusForVariable, the table's normal animation (smooth transitions between display positions) no longer happens- the table simply "jumps" from position to position. I haven't yet found a way to convince it to do otherwise- so far I've played with the order of my API calls, setting an animation layer in the table, adding an animation and calling refresharea, none with useful effect.
Anyone know if it's possible to convince a table to do fixed focus while still animating the movements between positions?
If not, I'll likely be requesting this from Sage
Cheers
Ikarius
SageTV 6.6.2, SageMC+CenterSage Theme
Server: Intel Core2 Q6600, 8gb memory, 3x 1tb WD EACS drives, software RAID5 2tb capacity, 4gb Flash boot drive, Ubuntu 8.0.4 Server edition
Capture: 1x HD-PVR -> Motorola DTC6200
Clients: 1x STX-HD100 1x STX-HD200, Windows & OSX Clients
Old 09-04-2009, 09:37 AM
PLUCKYHD PLUCKYHD is offline
Originally Posted by Ikarius View Post
Hey folks,
Cheers
Ikarius
Yes
How I do it is below the table cell put a panel widget
Under that panel widget do math to determine your location in the table (ie row/column)
Example
TableRow-VScrollIndex
>"1"
>"2"
etc this allows you to draw each element of the table seperately with panel widgets. Then use a item widget where you want to center/allow focus. This will cause the table to scroll and keep focus where you want. As long as everything is on the same layer the table will animate with the scroll (smooth i think it what is does by default)
The other way it to use arrays and draw a "dummy" table persay and animate the transitions from one to the other.
cheers
Old 09-14-2009, 03:04 AM
jaminben jaminben is offline
Originally Posted by PLUCKYHD View Post
Yes
How would you change the default animation of a table from Smooth to Morph?
I've looked at the tutorials (more Specifically Tutorial 17 – Core-Based Animations, page 131 /132) and searched the forums but can't see how you can specify a different table animation other than the table layer.
Cheers
Ben
Old 09-14-2009, 05:55 AM
Cheers
Ben
I don't think you can using the tables one of the limitations
Creating Arrays for tables PLUCKYHD SageTV Studio 37 05-31-2009 12:12 AM
Resizing Tables bialio SageTV Studio 5 01-22-2008 01:17 PM
Tables, Items, Focus (and Themes?) stanger89 SageTV Studio 14 12-20-2007 11:59 AM
Troubling Tables kuch68 SageTV Studio 5 09-13-2006 01:06 PM
