Old 03-06-2010, 06:12 PM
chalise chalise is offline
Must i buy sageTV to Develop a plugin?
Do i have to purchase Sage TV in order to develop for it?
I would like to develop a plug-in that grabs the raw TV signal or frequency that comes into my TV tuner. I have a Hauppauge WinTV-HVR-1800 HDTV PCIe.
is this possible?
Old 03-06-2010, 06:20 PM
GKusnick's Avatar
GKusnick GKusnick is offline
If you want to be able to continue debugging (and using) your plugin beyond the 21-day trial period, then yes, you'll need a valid SageTV license.
The SageTV API does not provide access to raw TV signals. What specifically are you trying to accomplish?
-- Greg
Old 03-08-2010, 07:39 AM
tmiranda's Avatar
tmiranda tmiranda is offline
I don't think you can even launch Studio on the trial version.
I think if you want to grab the raw signal you'd be better off interacting directly with the device driver and there is no way to do that through Sage. I'd do some Googling and checking on the Hauppauge site to see what the device driver API looks like.
Old 03-08-2010, 08:39 AM
is this possible?
You might want to look at TSReader:
http://www.coolstf.com/tsreader/
Old 03-11-2010, 07:28 PM
stanger89
Thanks, that's exactly what i was looking for! I spent a lot of time searching the net but never came across this. i was asking this question because i was gonna write my own program to do this but i guess i don't need to.
Thanks a to everyone who responded to my post and if anyone has information about other applications please post.
Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) cslatt SageTV Customizations 48 06-11-2012 10:44 AM
Hulu: Possible to Use XBMC Hulu Plugin to create SageTV Plugin? Brent SageTV Customizations 8 02-24-2009 04:16 PM
Don't buy HDHomerun from Buy.com (not an authorized reseller) Paul H The SageTV Community 3 05-28-2008 06:38 AM
Buy SageTV 2.x now, pay for SageTV 3.x? Will there be a Windows version? dspreadbury General Discussion 10 01-12-2005 09:49 AM
How to develop my own plug-in? Kalle SageTV Customizations 1 05-13-2004 12:02 AM
