SageTV Studio Discussion related to the SageTV Studio application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the Studio software application should be posted here. |
Calling methods on "Custom" Objects
Can you invoke methods on custom objects you are manipulating in studio?
For example, lets say one of static methods returns a List<CustomObject> which I use as the basis for a table. Inside of the table, each cell is set to an instance of CustomObject. Can I invoke a method on that object? I tried CustomObject_method() - which would return a string value - but it did not seem to execute that. I know I can have a static CustomObject.Method(CustomObject) method - and build that to perform the same action as the non static method.. But, I wanted to know if it was possible to invoke methods on custom objects in sage without resorting to that type of refactoring?
Host: ESXi 6.5 w/ Intel Core i7 2.8GHZ 8GB Ram Guest: Ubuntu 16.04 with Sage v9 in Docker Tuners: 2 HDHR (OTA); Extenders: HD300 connected to a Samsung 56" DLP HDTV; HD300 connected to a Sharp 42" LCD Storage: OmniOS w/6 1TB Samsung Spinpoint in a RaidZ2 configuration in a 20 bay SATA hotswap case. |
ObjectReference = intance of sagex.phoenix.MyCustomClass sagex_phoenix_MyCustomClass_MyNonStaticMethod(ObjectReference, AnyOtherArg1, AnyOtherArg2,...) If the method is static, then you do not need the ObjectReference, but the syntax is the same.
Ahh.. Ok, makes sense. Not much more convenient than having static method instead.
Thanks.
This is covered on p. 151 of the Studio manual.
-- Greg |
Thanks GKusnick - I looked through the manual but this particular part of method invocation still was not clear to me. But I see it there and understand it now.
It's also worth noting that to create a new Object from Studio use the full package and class name prefixed with new_
So if your class is Code:
com.package.my.CoolClass { void aGoodMethod(String S) { } } Code:
MyObject = new_com_package_my_CoolClass() Code:
com_package_my_CoolClass_aGoodMethod(MyObject, "the String")
Lost "Send To Custom Group" in My Videos | BFisher | SageMC Custom Interface | 1 | 02-07-2009 09:12 AM |
Is it possible to connect SageMC "Movie Now" menu to 1 of the custom button? | thenewguy1979 | SageMC Custom Interface | 2 | 09-19-2008 11:07 PM |
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting | maxpower | SageMC Custom Interface | 9 | 05-14-2008 09:44 PM |
Made a custom Aspect Ratio to "add overscan" on the HD100 | Slipshod | SageTV Media Extender | 8 | 03-27-2008 07:04 PM |
Change text of "Malore Custom Menus"? | YellowBox | SageTV Customizations | 0 | 08-14-2004 08:15 PM |
