Old 01-05-2011, 05:39 AM
21:9 Resolution?
What's the point here? Vizio just announced a new TV that sports it.
B
Old 01-05-2011, 07:12 AM
ability to show movies shot with a 2.35:1 aspect ratio (ie most blockbuster movies) full screen without black bars on the top and bottom (like on 16:9 televisions)
21:9 = 2.33:1
Cinescope
Check out TVExplorer
Old 01-05-2011, 07:19 AM
voidpt's Avatar
voidpt voidpt is offline
and the joy of having regular 16:9 broadcasts stretched or shown with black bars on sides. aaah, the joys of progress, marketing and standardization
SageTV 7.1.9 (headless/service) JavaRE 1.6.0_37 2x FloppyDTV C/CI (DVB-C) (fw: 1.2.10 B43110) (CAM: Conax) Win7 x64 Intel E3-1245V2 3.4GHz 16GB PC3-10600 ECC ASUS P8C WS (Intel C216) APC Back-UPS RS 800 STP-HD300 Extender (fw: beta 20110506 0) - HDMI/SPDIF - Yamaha RX-V2700 - HDMI - Sony KDL-52X2000
Old 01-05-2011, 07:23 AM
Nelbert Nelbert is offline
It's not aimed for general SD or HD viewing. It's aimed at 2.35:1 content.
Phillips release a couple in 2009 over here in the UK/Europe branded as Cinema 21:9 TVs. The starting price of 3000 made it even more niche than it's aspect ratio but they must have sold enough as they now have a 3D version of it on the market.
It's often a sought after resolution for projector users and removes the black bars seen watching 2.35:1 films on 16:9 screens.
Old 01-05-2011, 08:13 AM
Does it pillar box 16:9 content?
B
Old 01-05-2011, 08:43 AM
PLUCKYHD PLUCKYHD is offline
B
Yes or stretch it. But like others said it is not meant for HDTV 16x9 watching. I personally would be all over one for a theater room if I didn't already get that aspect from a projector and if it was a higher quality tv then vizio.
Old 01-05-2011, 08:56 AM
There are a "lot" of use (OK probably not a lot) that have been running this sort of setup for a long time, it's called Constant Image Height. Long story short, letterbox bars are the right way for movies to be shown. Movies have gotten wider and wider over the years, not shorter. A CIH setup, be it a 2.3x:1 projection screen and an anamorphic lens (or zooming) or a "21:9" TV, allows all aspect ratios to be shown in correct relation/proportion to each other, "scope" (2.3x:1) wider than HDTV (1.78:1), wider than SDTV (1.33:1).
http://www.widescreen.org/multimedia.shtml
Old 01-05-2011, 08:37 PM
ayjax's Avatar
ayjax ayjax is offline
I have to agree... A projector is the way to go for a movie room which is where this TV will most likely end up
Old 02-09-2011, 11:03 PM
benjatelcom benjatelcom is offline
Well Vizio's entry is compelling... Generally you can't touch a projector worthy, and the anamorphic lens for less than 5k. Plus a screen.
Hope we are seeing a trend towards anamorphic, and some projectors start shipping with the capability built in.
Intel NUC i7 SageTV and Plex
Synology NAS 4TB
Nextcom R5000 on Dish VIP211
Tablo DVR
4 HD300 Extenders
Old 02-10-2011, 06:47 AM
Yeah, except a 50" flat panel really isn't a substitute for a 120"+ projector
I doubt we'll see any projectors with integrated anamorphic optics, it's just too costly/complex. But there are already some native scope projectors out there:
http://www.avielo.com/product-optix-superwide235.html
I think Sim2 has or is going to have one as well. Kind of though there was another, but can't find it at the moment, maybe DPI.
Old 02-10-2011, 08:35 AM
My Panny AE4000 will do anamorphic without a separate lens. Granted it doesn't keep full resolution (ie it is wasted at top and bottom, but is the cheapest way I know to get 21:9 on a projection. I use mine at 16x9 though btw
What resolution is the setup UI? mtyme SageTV Media Extender 0 01-08-2010 10:12 AM
Resolution drops meno SageTV Software 4 09-21-2009 04:37 PM
Resolution problem SageGk SageTV Media Extender 2 09-30-2008 12:13 PM
TV-OUT/Change resolution Shplad SageTV Linux 2 01-11-2006 06:51 PM
Resolution Switching (Not just AR) cbryan27 SageTV Software 1 11-23-2005 07:47 AM
