Hauppauge 1600 Audio Clipping?
I have two HVR-1600's which capture via S-Video and stereo audio. I recently changed back to cable from DirectTv. Previously(D-Tv) once in a while would have the audio clipped. Since I switched back to cable using a Samsung SMT-C5320 STB, the audio always clips ~80% of the time.
I have HD300's for playback, and the stereo out on all (4) of my clients sounds sort of like rumbleing, which I interpret as the audio clipping, it happens on both cards. I shoud add that I have the latest drivers "18drv_28243" and my OS is 2008 R2 Server Standard edition, if that matters. Is there any way of limiting the input signal with the properties file or registry? Has anyone else encountered anything like this? Thanks, Skybolt Last edited by Skybolt; 10-21-2011 at 07:51 AM. Reason: Added OS and Driver info |
Does the stb have a volume option? Some of them are able to control the output volume of the stereo outputs. I use directv with my 1600 and don't have that issue. That's pretty strange.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
I had looked for that option, right now I have it set to "Fixed" and that made no differance. I agree this is very strange but it is so bad at times it almost mruins a show. Watching a dvd or other stored media (not redorded by Sage) works fine, which is why I believe it's the 1600. I also use an HDHOmeRun Prime and that is fine. So I need to believe ffDShow is set up correctly as well. The WAF is declinning quickly ...
I've had this problem too, I fixed it with a registry tweak: http://www.shspvr.com/smf/index.php?topic=10762.0
It might take a few tries before you find a satisfying volume level. |
-Skybolt |
You need to create the 5345Gain2 and 5345Gain3 values (as it says in the instructions). I'm not sure what 5005 value you are talking about.
Ok Thanks, I created the DWords and a value of ~75% (BF), the value of 5005 is what preceeds all of the existing keyvalues instead of 5345. I'll give both a try, and thanks again.
-Skybolt |
That did the trick, definetly takes lots of tweaking. -Skybolt |
From Tech Support
I ended up contacting tech support on this issue as the values did not seem linar in the audio response, and I also found scattered information on this but no one had ever posted the tech support information. So here goes:
The Reg Key: HKLM\SYSTEM\CurrentControlSet\Services\hcw18bda\Parameters The DWord parameters names: dword:"5345Gain2" //BackPanel dword:"5345Gain3" //FrontPanel dword:"5345Gain4" //FM Values for for all: 0x0 = 0dB 0x3e = -1dB 0x3c = -2dB 0x3a = -3dB 0x38 = -4dB 0x36 = -5dB 0x34 = -6dB 0x32 = -7dB 0x30 = -8dB 0x2e = -9dB 0x2c = -10dB 0x2a = -11dB 0x28 = -12dB all of the above values are in hex so you would enter 28 for the 0x28 value, but make sure Hexidecimal is selected when you enter the dword value. Also it seems that there are no "in between" values, meaning all values are absolute 0 = 0dB and 3e = -1dB there is no value for say -.5 dB. I hope this helps some one, as this was a real pain in the *ss for me. -Skybolt |
Added 2nd tuner (Hauppauge HVR-1600), no audio on analog, no digital tuner | jtimmes | SageTV Linux | 4 | 02-02-2010 10:22 PM |
audio stream in video is clipping | Belgrath | SageTV Software | 0 | 10-29-2009 01:01 PM |
PVR500 Audio Clipping on 2 Channels | sfisher | Hardware Support | 0 | 11-28-2005 01:17 PM |
Misc probs: DirectX filters, audio clipping, Windows Media Encoder | SageFL | Hardware Support | 4 | 04-04-2005 12:21 PM |
PVR250 Audio Clipping | srcurtis | Hardware Support | 5 | 01-25-2005 05:52 AM |
