Old 04-09-2012, 08:13 AM
loomdog32's Avatar
loomdog32 loomdog32 is offline
Missing "Missing Metadata" from BMT after Phoenix client install
Well, the title says it all.
After installing Phoenix on a client, I am missing "Missing Metadata" from BMT
Old 04-10-2012, 10:54 AM
I'm not sure what that means. Does BMT give you a message, "Missing Metadata", or are you saying that you are not seeing any metadata?
If it's a BMT web ui thing... then just try clearing your browser cache and then hit the BMT ui again... that should fix things up.
Old 04-11-2012, 03:58 PM
bialio's Avatar
bialio bialio is offline
Maybe he's missing the 'Missing Metadata' view?
PHOENIX 3 is here!
Old 04-20-2012, 10:40 AM
loomdog32's Avatar
I wouldve replied sooner, but Ive been on the road for work.
This is it. I will take a screencap when I get back home (hopefully ill get to go home this weekend).
I replaced the vfs.xml file hoping this would resolve the issue, but no joy.
Old 04-21-2012, 01:40 PM
Try using the "Refresh -> refresh configurations" menu option in BMT and see if it shows ups.
If not, then in the Browse screen, click on the double window icon to the Right of the "All Views" label and select Hidden Views, and see if the view is in there. If so, then click the plus icon to show it. You can con select All views, and it should show up again.
If not, then maybe when BMT was updated / installed, the bmt vfs additions didn't get extracted correctly. So, try uninstalling BMT and then reinstalling bmt... and for good measure, restart sagetv server and check again.
"Play a Playlist" option missing in Video Browser Bane SageTV Software 0 12-11-2011 02:07 AM
Phoenix - MYMOVIES Metadata and Missing Fanart on new install emotionnotion Phoenix 5 07-01-2011 02:43 PM
Netflix "Instant Queue" missing in SageTV menus boomxr SageTV Customizations 1 01-02-2010 10:02 AM
Any idea on why "native" sage thumbnail is missing color? stuckless SageTV Studio 5 10-15-2008 01:20 PM
Setup / Channel Lineup / DirecTV problem ("Done" is missing) aedgington SageTV Software 4 09-17-2006 04:14 PM
