Old 05-06-2012, 09:04 PM
I need a longer IR receiver cable
The supplied external IR receiver cable isn't long enough as I need to run the receiver from the front of the TV back to my HD-300 on a shelf. This unit uses a 2.5mm plug which is smaller than the standard mini headphone jack.
Taking a quick look at Monoprice they don't seem to have extension cables that are 2.5mm so is my best option to get a 2.5->3.5mm and a 3.5->2.5mm set of adapters and a 3.5mm extension cable?
Old 05-07-2012, 04:33 AM
Look at smarthome.com they are more focused on home automation and might have what you're looking for.
B
Old 05-07-2012, 07:27 AM
pukka pukka is offline
you could cut the cable and add a bit in the middle. soldering it back together.
Paul
Old 05-07-2012, 09:24 AM
Maybe you didn't see this one:
http://www.monoprice.com/products/pr...seq=1&format=2
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 05-07-2012, 10:54 AM
Thanks Keith, I missed that which may be because - the category it is listed under is Audio Cables - RCA & 3.5mm". They only seem to have the extension cables (Male on one end and female on the other) in 3ft lengths so I may need two of them or use the adapters and a longer cable.
I realize I can just cut and extend a cable but when you can buy one for <$3 it is hardly worth the effort.
Old 05-07-2012, 10:59 AM
Well, there's this one too:
http://www.amazon.com/gp/product/B00...n=&s=&v=glance
Old 05-07-2012, 02:33 PM
Paul H Paul H is offline
FYI: place to find IR stuff;
http://www.hometech.com/hts/products/infrared/emitters/
Old 05-07-2012, 06:54 PM
All of the emitters at Hometech seem to have 3.5mm plugs. Can you use an emitter with the HD-300 as it is actually working as an IR receiver, not a transmitter. And I also believe that the wiring is somewhat non—standard. I think I am just going to go with two of the 3 ft extenders as I need a total length of around 9 ft.
Old 05-07-2012, 07:00 PM
Did you see the 6 foot long extender cable that I posted three posts up?
Old 05-07-2012, 07:26 PM
Yes, I did but I need a bunch of other cables as well so I think I will just go with Monoprice - as shipping to Canada isn't always so cheap. That store on Amazon seems more expensive for other types of cables like HDMI, etc.
HD300 external IR receiver cable options? LehighBri SageTV Media Extender 8 12-07-2010 04:02 PM
3rd Party Cable Receiver Boxes mdnttoker Hardware Support 2 10-18-2008 06:25 PM
Splicing a Hauppauge IR Receiver cable jbarr Hardware Support 3 02-16-2007 09:21 AM
serial cable connect to sattelite receiver jca27 Hardware Support 2 01-20-2004 10:53 PM
longer cable for remote of PVR250/350 Sotto Hardware Support 0 10-08-2003 12:53 PM
