Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 09-28-2012, 08:32 PM
gveres gveres is offline
problem with widgets
I have enabled the widgets on an extender but nothing shows up in them.
I have enabled upcoming recordings to show up. The vertical divider shows up but it is black where the upcoming recordings should be.
Any suggestions?
Greg
Old 09-28-2012, 10:16 PM
jusjoken jusjoken is offline
Any suggestions?
Greg
I also answered your other post but this is the right place for this so here goes... try this.
Go into the Placeshifter Widget Manager settings and turn the Widgets to OFF... then turn them On again... I think this should work... it's a bug that eventually we need to tackle.
k
Old 09-29-2012, 07:02 AM
I had tried that many times to no avail.
What did work though was that I setup a placeshifter that did work, then I did a save all. I then loaded that set on all the other units and it worked.
Greg
Old 09-29-2012, 08:22 AM
After you turn them off stop and restart the sagetv service. the turn widgets back on.
Old 10-08-2012, 05:55 PM
bmh bmh is offline
I just updated to Gemstone this evening and have a similar problem with the widgets. They work fine on one extender but are blank on the other two. I tried turning them on and off and re-starting the service but there's no change. Is this a bug or did I miss something?
Old 10-10-2012, 12:08 PM
bmh bmh is offline
Greg
Greg,
How did you do a save all? I see an option for importing / exporting but have not tried this yet.
Old 10-12-2012, 05:08 AM
bmh bmh is offline
Exporting the widgets from the working extender and importing into the other 2 fixed this problem.
Old 10-12-2012, 12:04 PM
joenobody33 joenobody33 is offline
Yeah, I did exactly the same thing and it worked!.. Very weird.
Old 10-12-2012, 08:54 PM
I think I know the cause so I hope to get this fixed in another release.
k
Old 12-12-2012, 07:01 PM
KryptoNyte's Avatar
I'm going to bump this as I'm having the same results from an HD200. I enable the widgets, but the result is blank widgets.
Old 12-12-2012, 07:12 PM
KryptoNyte's Avatar
Turning the Widgets off (HD200), restarting the SageTV service on the server off and then back on, then turning the Widgets back on (HD200) worked.
Note that the HD300 did not require the start/stop of the SageTV service to show the Widgets immediately.
Old 12-12-2012, 09:15 PM
Thanks for the extra info...can I ask...do you only use the 2 extenders or do you ever use the client on the server and if you do..have you ever configured the widgets on the server client?
k
Old 12-13-2012, 05:05 PM
KryptoNyte's Avatar
I occasionally use the client(s) on both the server and another computer in the house. No, I have not configured either for widgets.
Live Widgets Dargason Gemstone for v7 1 09-08-2012 09:55 AM
Chain together effect widgets bialio SageTV Studio 1 01-11-2011 01:54 PM
Removing garbage widgets from STV dflachbart SageTV Studio 11 05-10-2006 09:10 AM
UI Widgets in loops DwarF SageTV Studio 6 01-24-2006 02:01 PM
