Old 03-04-2013, 08:04 PM
BUG: Missing Metadata View is Missing
It appears that I introduced a bug with my last round of Phoenix (I think nyplayer mentioned this as well), whereby the "Missing Metadata" a few other views no longer show up in BMT.
The work around for this..
1. Delete the file userdata/Phoenix/cache/vfs-cached.xml
2. In BMT use the Refresh -> Refresh Configurations
View should be back. I need to fix permanently, but I don't have the time right now
Old 03-05-2013, 11:11 PM
reggie14 reggie14 is offline
I noticed this, but it happened when I installed Gemstone so I attributed it to that.
I messed around with some configuration files and it came back. I honestly don't even know what I did, but whatever I did worked.
Anyways, it's good to know what caused it, and what the workaround is, in case it happens again.
Old 04-13-2013, 10:42 PM
Comitizer Comitizer is offline
Can't seem to get this working
Ok, so I just did a fresh install. Managed to get everything working ok but I still don't have the missing metadata view.
It's not ideal because I have a TON of stuff that didn't scrape during my initial run.
Any other ideas on how to get this back? I have a backup of my sage folder (from when everything was working correctly) from before my machine died so I can get files from there if needed.
Old 04-13-2013, 11:16 PM
Very off because in my cached VFS XML I can see the entries for missing metadata but when I go into the web interface I don't see anything.
Old 04-14-2013, 05:25 AM
Are you saying that in BMT you don't see a view called Missing Metadata? Or that you see the view, but when you click on it, you don't see any data?
Old 04-14-2013, 06:22 AM
rnadeau's Avatar
rnadeau rnadeau is offline
Menu option "Missing Metadata" has been missing since the last update.
Sage Tv Server-Amd 4200FX quad core, Asus Nvidia EN610 Hdmi out , 8 Gig Ram ,(3) HVR-1800, 3.5 terrabyte storage, Windows 8 Pro on sage 9.09 system . Media Server- 6 Terabytes on 5 drives, Amd x2 6000 8 useable gig ram on win 7 32 bit media server.
Old 04-14-2013, 08:16 AM
Right, I should have been more clear.
I don't see the view at all. It's not in the list.
Thank you so much for the reply stuckless.
Old 04-14-2013, 08:22 AM
Does it still not show up, if you delete the cached vfs file? Also I did find another issue in that code today (but deleting the cached vfs should have fixed it).
I'm going to try and push out a new phoenix build today, since it contains a couple of bug fixes and some P2 enhancements that are required for P2.
Old 04-14-2013, 08:24 AM
I assume you followed the steps the first post... ie, delete the cached vfs and then restart the server?
Also, that view is included as a part of BMT plugin, so you will need to have BMT installed. (just verifying that you do have bmt installed)
Old 04-14-2013, 12:47 PM
Yup, I followed the steps a couple of times. I even rebooted the entire server.
I also have BMT installed. I'm looking in the BMT web interface and I can't see the missing metadata view.
Old 04-14-2013, 02:04 PM
Could you verify that you have the file...
SAGE_HOME/plugins/bmtweb/Phoenix/vfs/bmt.xml
If not, then BMT didn't get extracted/installed correctly (you can try removing and re-adding bmt).
If you have the file, then send me the vfs-cached.xml file so that I can take a look at it. You can email me at metadatatools at gmail dot com.
Old 04-14-2013, 02:16 PM
I DO have the file so I guess BMT is installed correctly.
I just sent you the file from my gmail.
Missing "Missing Metadata" from BMT after Phoenix client install loomdog32 Phoenix 4 04-21-2012 01:40 PM
update vs. find metadata...I'm missing something Mr. Smartyman Batch Metadata Tools 1 05-03-2011 06:40 AM
Missing Metadata for Movies MilkmanCDN Batch Metadata Tools 4 04-04-2011 07:45 AM
Lookup Missing Metadata nyplayer Batch Metadata Tools 6 02-05-2011 08:36 AM
Default for Missing Metadata - TV instead? ohpleaseno Batch Metadata Tools 4 01-11-2011 02:03 PM
