Old 06-30-2004, 02:57 PM
jag555 jag555 is offline
Playing movie: Time scrolling issue
I've a bizarre behavior.
When I watch a recorded movie, the "time scrolling indicator" (located above the bar) goes much faster that it should.
The result is that it reaches the right side before the end of the movie and the player stop.
What do I do wrong?
Thank you very much for your help,
Jean
Old 06-30-2004, 06:46 PM
beautye350 beautye350 is offline
I've noted similar behavior. Usually closing the file and reopening it fixes the problem. If not, I close and reopen sage. The recorded file is fine in my case, just an anomaly in playback.
Long story short...I don't think you are doing anything wrong.
I've also posted some issues I've seen with picture corruption where sage has a sort of double vision. Possibly java issues we are seeing.
See:
Anyone seen this corruption before?
Regards,
Beau
Old 07-01-2004, 10:08 AM
Thank you very much Beau.
The recorded files seem not corrupted, neither. I can play it with another player (WinDVD).
Just when I play movies inside Sage, it plays only for few minutes, and stop when the scroller arrive to the end prematurely. Then I've to reposition manualy the scroller. Restarting do not seem to change anything.
Thank you,
Jean
Old 07-01-2004, 10:19 AM
falchulk falchulk is offline
jag555, I have seen this happen, but only on files stored on network drives. I ran a defrag on that drive and when I reopend sage, it was correct! Now, I am not sayingthe defrag fixed it but I have had no problem with it since.
