TV section is gone...from client
Hi all,
I now have a fully working SageTV v9 server, with HD-PVR & full EPG (from XMLTV). ![]() So, I installed the Client on another computer...but the TV section is missing ![]() I tried both the old v7 install & upgrade the Jar & exe etc and the new beta installer. Same results. Any idea? Thanks, Oren.
Oren Shapir - Architect |
Also gone are all the plugins...The plugin screen is empty.
![]() Installed on another cmputer - the same results. ![]() Oren.
fixed the problem by clean install of v7 of SageTV, then update to v9 using the new JAR & exe files. Both on the server and the client.
There must be someting wrong with the SageTV v9 Beat install... ![]() Oren.
Which beta version did you use?
I used "SageTVSetup_9.0.3.194_beta0.001" and "SageTVClientSetup_9.0.3.194_beta0.001"
Oren.
You could try .002 as MUCH has changed. |
BTW: the only way that the top level TV menu is not shown on the main menu is if the API call IsPVR() returns false... which according to the docs says happens when it is not connected to a server that has PVR capability. Not sure how that applies here; just mentioning when that menu item wouldn't be shown.
Andy
Here we go:
Thu 1/21 20:15:52.254 [TimeoutHandler@46b40d] TIMEOUT occurred - close the socket asynchronously for Socket[addr=/127.0.0.1,port=52436,localport=42024] Thu 1/21 20:15:52.260 [SageTVServer@86ca93] Error w/SageTV client connection:java.net.SocketException: Socket closed Thu 1/21 20:15:52.265 [SageTVServer@86ca93] Cleaning up c/s connection Thu 1/21 20:15:52.270 [SageTVServer@86ca93] SageTV received connection from:Socket[addr=/127.0.0.1,port=52442,localport=42024] Thu 1/21 20:15:52.274 [SageTVServer@86ca93] Cleaning up new connection because we can't match it up newName=/127.0.0.1:52436 map={} Thu 1/21 20:15:52.281 [SageTVServer@86ca93] Cleaning up c/s connection |
Addendum: External client is also fine (V9). .
Athlon II Quad Core 3Ghz, 8GB Ram. 12GB Storage. 3 (x4) HDHR for OTA Across 2 Cities, HD200, 2x HD300. Last edited by BobbyDing; 01-22-2016 at 10:43 AM. |
v9 as well.
I keep the windows firewall disabled because it only causes issues and it's redundant considering the firewall on the router. I don't know where to get the client log... the above was from sagetv_0.txt.
v9 installed with what version of the installer or manually?
Manually from the zips that was given when it went open source originally. I seem to have fixed the problem by running the beta installer though. Strange thing is that even restoring everything from backups from before the issue came up didn't seem to fix it.
Thanks, Bobby
Athlon II Quad Core 3Ghz, 8GB Ram. 12GB Storage. 3 (x4) HDHR for OTA Across 2 Cities, HD200, 2x HD300. |
Full server, since that's what I have on my system.
The only other reason this would occur is if a pirated version of SageTV is being used (that's determined in the EXE)...however, we've removed all the code that would cause behaviors like this from V9, so if you're using V9...you're definitely not triggering that part of the code (even if you're using a pirated EXE with the V9 JAR it wouldn't trigger this). And even if that was it...it's very randomized...so you wouldn't see the same behavior repeatedly (unless you didn't restart the portion that's generating the UI).
After some thought (it happens occasionally), I remembered that I recently added the Always Show Sub menues plugin remotely from (and for) the the android miniclient. After removing that plugin (again from the miniclient) the server client works as usual. That plugin makes for less swiping on the tablet, so I may need to try DarkWolf77's fix. Unless there's a way of disabling that plugin on the server client without actually using the plugins menu on the server client?? Maybe if I install the plugin using the server client?
This V9 was manually installed over a working V7. Back in October (if that makes any difference). Bobby UPDATE: For anybody else whom has this issue. I am not yet ready to play too much with updating the server (it's a WAF thing). What gave me a fix was I loaded Always Show Sub Menus via the HD300 and the second level menus disappeared again from the server client. But I was able to right click on the SageTV client and then disabling ADM brought "all" the sub menus back. From there I could disable the Always Show Sub Menus plugin on the server client. After re enabling ADM, all is working fine. I will try installing the latest beta in the near future, when the server is not so busy. .
Athlon II Quad Core 3Ghz, 8GB Ram. 12GB Storage. 3 (x4) HDHR for OTA Across 2 Cities, HD200, 2x HD300. Last edited by BobbyDing; 01-25-2016 at 10:32 PM. |
Creating a Kids section? | damonbrodie | Gemstone for v7 | 14 | 10-23-2012 11:49 AM |
M4V's in the DVD/BD section? | BitBass | SageTV Software | 0 | 03-12-2011 09:23 AM |
Have .mkv show as DVD's in Video section? | Biggen | SageTV v7 Customizations | 2 | 11-01-2010 02:55 PM |
HD-300 DVD/Blu-ray section | rugerp90 | SageTV HD Theater - Media Player | 1 | 10-27-2010 06:15 AM |
Only Use Music Section of SageMC? | Flips | SageMC Custom Interface | 9 | 08-07-2006 05:26 PM |
