Old 04-09-2016, 07:57 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Circularities, sometimes.....
I have an stvi that when installed via the plugin manager generates circularities. There are no circularities in the source and when I import it through the detailed setup menu it does not generate circularities.
Anybody ever seen this before?
Old 04-09-2016, 02:25 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I see it all the time in V9. Looks like some widget references aren't being followed in Studio.
If I change the primary reference that the widgets shown as circularities sit beneath, the circularities disappear. I does seem to just be a Studio issue though as the code in my case still works OK in SageTV.
John
Old 04-09-2016, 03:15 PM
tmiranda's Avatar
John
I made some changes in my code and the circularities went away. Looking back, I see I changed the primary reference as you noted.
Circularities dflachbart SageTV Studio 3 02-16-2006 08:47 PM
