Old 03-23-2018, 11:54 AM
snipeman's Avatar
snipeman snipeman is offline
Recommended procedure to swap tuners From: Avermedia Duet PCi-E To: HDHR Quatro
Later this year I want to upgrade my Sage server. To lay the groundwork I want to change my tuner now. Currently I have an AVerMedia Duet PCI-E tuner inside a tower box.
I've ordered a HD HOMERUN Quatro which is on the way. My thinking is that if I go to an external tuner now it will make it easier to downsize to a small form factor server later.
I only use antenna for my signals, no cablecard.
My server is Sage 9.1.8 on Win 7 Enterprise. I run Sage as a minimized application not a service. I also run Comskip and Plex Server, (Comskip via Sage not Plex or MCEBUDDY)
I don't need 6 tuners, the Quatro will be fine. Should I remove the PCI-E tuner card and drivers first, install HDHR software and scan with their software? Finally wake Sage up remove the old 2 tuners and add the 4 new ones?
Is there any complications with Schedules Direct when switching tuner types or going from 2 to 4 tuners? Does Sage need to be running or exited when installing the HDHR software?
I've read a lot of messages on these forms to learn but a lot of the info is very dated.
Any tips to make it a smooth process before I begin would be appreciated. I've always had internal tuners, this will be my first experience with an HDHR.
Server: Win7, SageTV 9.1.8, Avermedia Duet dual tuner ATSC ,Intel I7-3770T Ivy, 8GB RAM, 4TB of Green WD SATA AHCI, Comskip, 2 SageClient, 2 HD300, 1 PlaceShifter
Old 03-23-2018, 12:17 PM
If I were you I would first install at least one of the Quatro tuners and make sure it looks good. Once that is working for a few days and everything looks good you could start by removing/deleting the AverMedia tuners. No point in removing the PCI-E card unless you want to use it somewhere else.
You might have to change the tuner merit to ensure that the Quatro is used.
Old 03-24-2018, 05:00 PM
snipeman's Avatar
Thanks for the suggestion, it is a good idea. I would have to find a 2nd antenna to hook up to make that work as my only antenna is connected to the Avermedia.
Do you know if Sage needs to be running or closed to install the HDHOMERUN software?
Old 03-24-2018, 05:02 PM
I am not sure but I am pretty sure that you will have to restart Sage in order for it to find the new tuners. So you may as well shut it down for a minute while you do the install.
Old 03-24-2018, 07:16 PM
And you shouldn't need a second antenna - a splitter should do the job and you can feed both the Avermedia and the HDHR. But if your signal levels are low you may need an amplified splitter or distribution amplifier. I use something like this to feed multiple tuners and TVs:
https://www.amazon.com/Digital-Ampli...tion+amplifier
Recommended Upgrade Procedure? Polypro Diamond 7 04-08-2011 09:40 AM
Anyone tried the AVerMedia AVerTVHD Duet yet? hingepin Hardware Support 63 05-26-2010 04:37 PM
AverMedia A188c (hd duet) and WHS rykr Hardware Support 2 03-09-2010 05:14 PM
Recommendation: 2250 or Avermedia Duet? rykr Hardware Support 11 10-27-2009 09:35 PM
QAM with AverMedia HD Duet? eastfamily Hardware Support 0 09-17-2009 08:27 AM
