Old 04-20-2006, 06:04 AM
hummedan hummedan is offline
SageTVService.exe Memory Resources
Hello,
I currently use Sage on one server w/ one MVP and placeshift w/ a remote laptop. I just installed RC .14 and all seems fine but i noticed that the SageTVService is using between 87MB and 99MB of memory and it only seems to grow.
Is this normal or is this a possible memory leak?
P-4 3.2gHz HT, Hauppauge 350, 1.5GB RAM, 500GB HDD, Nvidia 6600gt
Old 04-20-2006, 10:02 AM
Normal-it will get cleaned up later by java. Usually the later versions of java do a better job of memory management.
