Old 04-11-2007, 06:12 PM
chorscroft chorscroft is offline
Using a Phillips MCE remote with sage
Old 04-11-2007, 06:32 PM
Originally Posted by chorscroft View Post
Hi there,
I recently bought a phillips MCE remote off ebay - listed here http://cgi.ebay.co.uk/ws/eBayISAPI.d...4919&rd=1&rd=1
- and hoped to use it with sagetv however when I plug it in and select MCE remote from sage it doesnt work. I press a button and I get a light on the remote and a light on the receiver but none of the buttons work with either sage or windows. I've looked around a bit and it seems I may have to use a program called girder?
Could someone please explain to me how to get this remote working with sage.
Thanks in Advance
Conor
Make sure you're using Windows XP Service Pack 2 and make sure the receiver shows up in Device Manager as eHome receiver or something like that. Then reboot and make sure MCE remote is chosen in Sage. It should just work.
Old 04-12-2007, 01:06 AM
brewston brewston is offline
Hi
Have a read of this thread :
http://forums.sagetv.com/forums/showthread.php?t=17261
specifically, the 2nd post with the link the drivers on microsoft.com
I have the same remote and with those installed it works fine. The only downside was that the power button would shut down the PC, if you don't want this to happen then use Stephane's keymapper to map the button to something else
Tim
Tecra M5, 2 x HD200, 2 x HD300
2 x PCTV 290e
Win 7, Sage 7.1.9, Phoenix 2 STV
Stephane's XMLTV Importer, Digiguide,
Old 04-12-2007, 11:38 AM
Polypro Polypro is offline
You could also set XP's Power Management options to "Ask Me What To Do" for the Shut Down and Sleep functions.
P
Firefly remote & Sage TV 5 ? davefred99 Hardware Support 7 05-12-2006 08:12 AM
Problem getting the MCE Remote Green Button to work bitbyte Hardware Support 10 05-09-2006 03:59 PM
Do i have my remote control options understood orangezero Hardware Support 6 05-05-2006 10:32 PM
