quad core vs dual core
I'm still trying to decide on quad core processor vs. dual core processor..
Q6600 vs E8400 2.4 per core vs 3.0 per core.... Will sage use 4 cores, or is 2 enough.? ..I'd love to have the extra Ghz in the dual core and the FSB is higher in the dual core... Comments? Gary Ellis |
Personally, I would go with the Q6600 and a slight overclock to get it to 3.0Ghz. I've got an E6600 at 3.6Ghz and it's working it's tail off to do compskip and Autoencode on all the kid's shows. It works, but I wish I had four cores.
I just upgraded from an E4500 to Q6600. The quad core is definitely the way to go if you are using MVPs or compressing the files. The difference is absolutely incredible. I OC'd it to 3.0 before even booting and nothing could be easier. I'm currently running at 3.2 and once I replace my memory I'll be shooting for either 3.4 or 3.6.
It's complete overkill for sage server, though I have to say I like overkill in general... :-)
Server: Sage 6.5.9 - X2 3800+, DFI NF4 MB, 1 GB, 300 GB HD (system disk), NV 7600GS, - Windows XP SP2 Client 1: Sage 6.5.9 - E7200, Abit IP35 Pro, ATI 4850 with HDMI connect to Denon 3808CI and Sony A3000 SXRD TV Client 2: HD200 connected to Denon 3808CI and A3000 SXRD TV Client 3: Media MVP to 15" Toshiba LCD Client 4: HD100 connected to Samsung 23" 720P LCD Client 5: HD100 connected to Vizio VX37L |
Server - unRAID 6.1.3: VM-Windows7 with Sage 7.1.9 - 2xHDHomeRun 1xHDHomeRun Prime - Xeon E3-1230, SUPERMICRO MBD-X9SCM-F MB, RAM 16 GB, HD 14TB Clients: 2xHD100, 1xHD200 and 1xHD300 |
Thanks for the great feedback...
Now for the motherboard assuming a Q6600 processor... Should I go for the x38 northbridge or is P35 plenty for this processor? only about $30 to $50 difference in Mobo's between P35 and x38. Also for memory...looks like 1033 is the right size.... 1600 costs too much. comments..?? x38 and 1600 both seem like more overkill..but, I do like the upside potential of the x38 board... Gary Ellis |
What you do want is to make sure you have lots of PCI slots for tuners etc... Also, if it has a realtek GbE chip, I'd get an Intel or Marvell PCI-E GbE controller, just to make sure it can feed lots of HD100's without running out of gas. If you find a P35 board with a marvell GbE chip on board, then you don't need the addon card. 1394 is handy if you want to play with firewire tuners...
I bought a ABIT IP35 Pro for my Q6600, couldn't be happier. 3 standard PCI slots, dual gigabit LAN, and two 1394a... Dirk |
OT: could a dual gig-e be split between my LAN and a separate switch to handle just HDHRs? that's assuming the local service doesn't force me into STB bondage in the near future.
Server: MS Win7 SP1; FX8350 (H2O cooled); 8GB RAM; Hauppauge HVR-7164 (OTA); HVR-885 (OTA); SageTV 9.1.5.x; 12+TB Sage Storage Clients: HD300 x2; HD200 x2; Placeshifter Service: EPB Fiber (1Gb); OTA (we "cut the cord"); Netflix, Hulu, etc. |
OK..I bought the Q6600 and the Abit IP35 Mobo and corsair 2x2GB 800 (PC2 6400) memory...
Now can't wait for it to get here... Thanks all for the help, Gary |
I agree, the ABit IP-35 Pro mobo is an excellent choice. When I did the mobo researching, the ABit IP-35 Pro had a very small number of negative reviews.
The ABit IP-35 Pro mobo works great with the dual-core E6850, and should also be an excellent choice with the Q6600. You might want to make sure the Q6600 is a "G0" if you want to over clock it, since "G0" overclocks better. Newegg won't tell you if they will sell you a "G0". You can specifically order a "G0" from Tank Guys http://www.tankguys.biz/ Dave
SageTV: LIAN LI PC-K58, Gigabyte GA-EX580UD5, i-7 950 3.06 gig quad LGA 1366 CPU, Zalman CNPS9700 CPU cooler 1366 bracket, Memory 24 gigs GB, PNY NVIDIA GeoForce 9800 GT 1024 MB, Corsair 750w PSU, Samsung 500GB SSD boot, 3 SSD recording drives Capture cards: 2 - HDHR Primes - Comcast Xfinity CableTV Extenders: 1-HD-300, 2-HD-200 Software: Windows 7 Pro X64, Ghost 15, VideoReDo TVSuite 4 h.264, Playon (Netflix), OpenDCT UnRAID File Server 4.7 Pro: Lian-Li PC-G70B, MBD-X8SIL-F-O, i3-540, 16 TB |
Wayne |
They easily overclock to 3Ghz, most to 3.6Ghz, though this is complete overkill for Sage server. The IP35 Pro has a realtek GbE, so you might want to get a marvell or intel one if feeding a lot of HD100's HD...
Server: Sage 6.5.9 - X2 3800+, DFI NF4 MB, 1 GB, 300 GB HD (system disk), NV 7600GS, - Windows XP SP2 Client 1: Sage 6.5.9 - E7200, Abit IP35 Pro, ATI 4850 with HDMI connect to Denon 3808CI and Sony A3000 SXRD TV Client 2: HD200 connected to Denon 3808CI and A3000 SXRD TV Client 3: Media MVP to 15" Toshiba LCD Client 4: HD100 connected to Samsung 23" 720P LCD Client 5: HD100 connected to Vizio VX37L Last edited by mikesm; 03-13-2008 at 03:55 PM. |
Silly question...does XP support Quad core? Or would I need vista?
Yes XP supports it. I have one and have been very happy with it.
Does it need to be XP Pro?
HD Homerun and DUAL CORE processors | srothwell | Hardware Support | 12 | 04-28-2007 09:44 AM |
Dual Core processors and Placeshifting | ldavis | SageTV Placeshifter | 5 | 04-13-2007 05:16 AM |
Dual Core? | KorCar1 | Hardware Support | 11 | 07-24-2006 03:39 AM |
Dual or single core for "smoother" HD playback | trini0 | Hardware Support | 3 | 03-12-2006 05:32 PM |
Anyone running a AMD X2 or Dual Core system for a Server | edbmdave | Hardware Support | 5 | 02-06-2006 09:58 PM |
