Old 06-25-2008, 10:53 AM
clawes clawes is offline
Question Getting Rogers digital channel
I'm presently using SageTv to record analog channels (1-28) for my Canadian cable provider, Rogers. I would like record shows in the higher, digital channels. How I would go about connecting my Rogers digital box to my SageTV server so that I can record shows in the digital channels (30-74)?
I'm using an Hauppauge PVR 150 TV tuner card with remote. Will Sage be able to control the digital box to change channels?
Old 06-25-2008, 01:08 PM
Swagger200 Swagger200 is offline
Connect s-video and audio from your Rogers box to the PVR 150. I believe the 150 comes with an IR blaster which you can configure within Sage to change your channels, though I haven't tried that yet.
(Better option) For all digital channels AND HD, get an HD-PVR from Hauppauge and connect that via USB to your Sage server.
[SIZE="1"][I]Server 1: i5-2500k, Win10 Pro, Cisco 4642HD -> Hauppauge HD-PVR
Server 2: Thinkpad W530, Win10 Pro, Cisco 9865HD -> Hauppauge HD-PVR
Server 3: Thinkpad W530, Win10 Pro, Cisco 4642HD -> Hauppauge HD-PVR
Clients: (3x) SageTV HD-200, (1x) SageTV HD-300, SageTV Client on several PC's, SageTV Android on FireSticks and Nvidia Shield Pro/SIZE]
Sage UIRT channel problem Cynesyn Hardware Support 0 04-02-2008 08:58 PM
Intermittent channel change problem appelm SageTV Software 4 11-17-2007 08:23 AM
Channel mix up rfutscher Hardware Support 0 11-03-2005 06:39 PM
Recording Disabled Channel tahoebob SageTV Software 0 11-03-2005 02:14 PM
How many channels do you get? edgley SageTV United Kingdom 11 07-25-2004 02:17 PM
