Haupppauge 45 remote and device address codes
I have 2 Starchoice satellite receivers that use UHF remotes. Each receiver can be given a different, three-digit address code (000, 001, 002, etc.) to avoid the wrong remote changing channels on the wrong receiver.
Problem: If I use any other address code other than 000, the Hauppauge remote fails to communicate with the Starchoice receiver. Since I need to use address 000 on one box (Tivo limitation), I need to have the Hauppage control a receiver with an address other than 000. Is Sage capable of this? Is there somewhere in the .ini file (or similar) that the Hauppauge remote address can be altered to anything other than 000? thanks |
Is it possible I didn't explain this properly?
The Hauppauge seems to operate just like the Tivo, in that it doesn't seem to communicate with a receiver unless the receiver's remote address is 000. Is there a line of code in the iremote.ini that would enable addresses other than 000 (001,002, etc). I have called Hauppauge, but no help there. thanks |
I can't answer your question, but maybe with clarification someone else can.
A couple of questions to clear up what you are trying to do: When you mention the Hauppage remote, do you mean the IR blaster from a capture device? The remote is not going to do anything to your sat box. Is the Starchoice receiver capable of being controlled by an IR remote, cuz the Hauppage blaster is not going to do UHF.
unRaid Server:Quad-Core Xenon, 20 GB Ram, openDCT/sageTV Dockers, HDHR,HDHR Prime Network Encoder:Dell Inspiron 1000 Laptop, 512MB Ram, Windows XP, HDPVR |
The Starchoice receiver is basically a re-branded Motorola; DSR-505. It is capable of being controlled by both IR and UHF. The included Starchoice remote will continue to control the receiver via IR after you have changed the receiver's remote address (from it's native 000 to either 001, 002, etc), whereas the Hauppauge remote/IR blaster can't seem to communicate with the receiver after the address has been changed from the native 000 address. |
do you change the address on the receiver or the remote
Actually the address is changed for both devices - they are paired together at whatever address number (000,001 etc) you select.
The remote is used to implement the change, but I believe you can program the receiver independently from the front panel controls. |
Information Resources for Remotes, Receivers, and IR Blasters | Opus4 | Hardware Support | 4 | 09-17-2009 01:37 PM |
URC MX-700 remote layout for the STX-HD100 extender | Opus4 | Hardware Support | 44 | 02-05-2009 12:03 PM |
Sony LF-PK1 Remote codes | Bacon2002 | SageTV Media Extender | 1 | 08-02-2008 10:19 AM |
small Hauppague remote doesn't work right on new computer | weyker | Hardware Support | 1 | 04-08-2006 03:18 PM |
No audio or video | HairBear | SageTV Linux | 28 | 03-17-2006 05:48 PM |
