Go Back   SageTV Community > SageTV International User Forums > SageTV Canada
SageTV Canada SageTV and SageTV Recorder Users from Canada - This forum is for you to post about specific issues using SageTV software in Canada.
Old 03-03-2010, 09:43 PM
toony toony is offline
channel changing via firewire on Rogers 4250
Just wondering if anyone could point me in the right direction as to how to set up the channel changing via fire wire on the 4250 HD?
Cheers
2xhd300
Old 03-04-2010, 12:17 PM
Naylia's Avatar
Naylia Naylia is offline
Go Here. I know, it's a really big thread but there should be pointers at the front to the relevant sections if you don't want to read five years of firewire configuring.
You can find me at Missing Remote. Or playing FF XIV. For XLobby users: XLobby MC
Old 06-19-2010, 12:44 PM
pvrpenguin pvrpenguin is offline
I was able to get my 4250 successfully configured for firewire changing using the above link. It definitely isn't straightforward but does work. Let me know if you run into problems.
Windows 7 64bit (2.5 GHz, 4GB RAM, 2 TB storage), HVR 2250, HD300, HD200
Plugins: Gemstone
Old 06-21-2010, 02:45 PM
What drivers did you use? A couple of years ago I had trouble getting the 4250s to work but I didn't bother spending any time to troubleshoot since I had 3250s at other TVs in my house so I just moved the 3250s to my Sage PC/HD-PVRs and they worked fine with the original firestb drivers.
rogers 3250 / 4250 HD box with HD PVR -> sage tv? toony SageTV Canada 6 03-02-2010 04:49 PM
Channel changing via Firewire showson1 Hardware Support 1 10-15-2008 02:08 PM
Did 6.4.5 break FireWire channel changing? mihooper SageTV Beta Test Software 3 07-24-2008 07:51 PM
Firewire channel changing gjvrieze Hardware Support 4 07-07-2008 03:05 PM
firewire channel changing question GbrNole Hardware Support 14 12-17-2007 11:21 PM
