UPnP Browser: The Video List is Downloading
I upgraded to Version 7 and the new plugin didn't make this problem go away for me.
When I ultimately click through to the Browser, I see the "The Video List is Downloading" box forever. PlayOn is running on my server, there is no anti-virus or firewall running. The plugin was working fine before until one day (on V6) when I got this behaviour (which has carried over into V7) How can I debug it? On V6, the log was empty, and UPnPBrowser just hung when I ran it from the command line. Help! |
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink) |
Well, when you put it that way ;-)
If I run it w/o any parameters, it does come back w/ output (attached) and the log is generated (also attached) when I run UPnP2Podcast.exe "PlayOn:Hulu:+2" debug to test, is when it hangs and there's no log Mike |
UPnPBrowser.exe is the new version for v7. Try running that. It should be in the folder SageOnlineServicesEXEs.
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink) Last edited by evilpenguin; 05-21-2010 at 12:10 PM. |
Thanks! I ran UPnPBrowser.exe once (no parameters) and renamed UPnP2Podcast.exe to UPnP2Podcast.exe.xxxx, went back in through the UI, and it works again!
OnLine Videos freeze
I am now running SageTV MC Ver 7 beta. I've updated my firmware and installed the UpnpBrowser plug-in. I am running the latest version of PlayOn (2.59.3790.84). When I browse PlayOn's lists using UpnpBrowser and select a TV show to watch, the show may start but after a very short time the video freezes. It will try to play but it quickly freezes. I checked my computer and the MediaMailServer.exe service was consuming all the CPU time. I have to delete that process in order to gain control back.
These same symptoms happened when I was running SageTV Ver 6.6. with your Upnp2Podcast plug-in, but ONLY after I upgraded from PlayOn Ver 2.59.3686 to ver 2.59.3699. Prior to the upgrade all Online videos ran smoothly. I contacted PlayOn and they suggested installing XBMC to browse PlayOn's list and play a video on my computer. The video played smoothly using XBMC but did not work using SageTV. I am including a log file of one of my attempts at playing a video. I upgraded to SageTV Ver 7 hoping it would fix the probelm. It did not. |
Do Hulu videos work, or is it just CBS giving your the problem? I've had no issues with the latest version of PlayON so I don't know what could be happening.
Edit: Also, is SageTV actually freezing, or is the video just stopping earlier than expected?
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink) Last edited by evilpenguin; 06-07-2010 at 02:46 PM. |
I should mention that "native" SageTV Online Services, those which come with SageTV like YouTube and Google video work fine. Only when I browse PlayOn then play a video does the problem occur. I did check the PlayOn forums and some PlayOn plug-ins cause similar problems, but I am not using any PlayOn plug-ins. |
I did check the PlayOn forums and some PlayOn plug-ins cause similar problems, but I am not using any PlayOn plug-ins. I did rename the Plug-In folder as they suggested anyway but it did no good. I will continue to search the PlayOn forums.
Video Freezing even with SageTV Media Player
I did some more exploring with the Video "freezing" problem I had. I used just the HD200 as a SageTV Media Player and not interfacing with the SageTV Server. In this mode I go to "File Servers" and the PlayOn server shows up so I can browse the various offerings. When I go to play a video the same thing happens as I described in my previous posts, that is the "downloading" message box takes forever and the video stops (freezes). The freezing is the result of the PlayOn server consuming 100% of the CPU. Native SageTV "OnLine" videos play fine.
This means the EP's plugin is not the cuprit, but rather the interaction between SageTV and PlayOn. PlayOn has no problem when used with XBMC. PlayON was working with SageTV until I upgraded. I believe this is no longer the best forum for a probem of this type. Any suggestions as to which forum would be the best to submit this problem would be appreciated. Thanks |
Damn Damn Damn.
It was all working great with TVersity. UPnPBrowser was able to find TVersity and give me a list of videos. I had to get greedy and install playOn. Now I get "video list is downloading" The UPnP Browser stays at 16Mb memory for a few seconds - then rockets up to use 1.5Gb where it levels out. No video list appears. I tried uninstalling playon and restarting SageTV but it does the same thing. Anyone know how I can fix this? Michael |
Sorted it.
I just deleted the cache of data in the UPnPBrowser directory and tried again. |
This problem just popped up today - I tried clearing my google chrome cache and now it just sits there for like 5 minutes saying "the video list is downloading" and then comes up blank. I tried reinstalling PlayOn - no luck.
I'm not sure what to do. On another note - is there ANY way to search Netflix (I mean like you can with Roku or others where you can enter the name of a show or movies?). It seems like all you can do is navigate through menu topics to try and find what you are looking for. Thanks, |
Online Services Plugin :: UPnP Browser | evilpenguin | SageTV v7 Customizations | 82 | 06-07-2010 02:14 PM |
UPnP Browser showing no videos found | jpaddock3000 | SageTV v7 Customizations | 1 | 05-20-2010 01:29 PM |
Video Browser Search | JREkiwi | SageTV Studio | 24 | 04-26-2007 11:00 PM |
How to import video and have it appear in Recorded TV list | LehighBri | SageTV Software | 2 | 11-20-2006 08:48 AM |
Copied DVDs don't list in video library | mleonard | SageTV Software | 7 | 11-12-2006 10:13 AM |
