Go Back   SageTV Community > SageTV International User Forums > SageTV Canada
SageTV Canada SageTV and SageTV Recorder Users from Canada - This forum is for you to post about specific issues using SageTV software in Canada.
Old 12-06-2010, 12:25 PM
Anyone using firewire with Rogers SA4250HD? (channel changing only)
I have been using firewire channel changing with two SA3250HDs (hooked up to HD-PVRs) for a couple of years.
When I set up a server about two years ago I tried using a SA4250HD but the Tim M Moore drivers didn't seem to work. There were some other drivers (from here) that I quickly tried but then I just figured no point playing around and I switched boxes so that I was using a 3250HD rather than a 4250HD.
It now looks like one of my 3250HD boxes may be dying (it reboots every day or so for no apparent reason) and I don't have another one to use in its place. I have a 4250HD that I could move to this location but then I need the firewire to work for channel changing.
Has anyone successfully used a 4250HD from Rogers for channel chaning via firewire? If so what drivers did you use and do you have to use any of the addional parameters (like -f4)?
Old 12-06-2010, 04:13 PM
DMT DMT is offline
I have 2 Rogers SA 4250HDs using firewire channel changing.
I think I used the drivers included with Timmmoore but I might have used these stb_firewire_drivers_2009-02-25
-f -a4 -n used to work but as of June 2010 I had to change to f a6 n
Channel changes have always been 100% accurate.
SageTV 7.1.9 on Win 7 Ultimate x86; Intel DH67CF, i3-2100T, 4GB DDR3, 60GB SSD, 8TB Drive Bender storage pool, blu-ray. 2x HD PVR (SA 4250HD firewire channel change), 2x HD200 extenders (external IR receiver mod, HD300 remotes).
Plugins: Custom Main Menu, Enable/Disable Favorites, Stock Manager, Web Interface, Mobile Web Interface, PlayOn
Old 12-06-2010, 04:17 PM
Thanks - I will look for those drivers. I have also never had problems with channel changes but my SA3200 with a USB-UIRT IR emitter taped to the front also rarely has problems.
Did you notice if Rogers did a software upgrade in June to require the change?
Old 12-06-2010, 04:22 PM
DMT DMT is offline
Yes, it was a Rogers update.
Old 12-18-2010, 09:58 AM
I had promised some folks an update on this issue. As a refresh - I have been using Rogers 3250HD boxes with Sage for years but one of my boxes died. I am also in the process of building a new server running Win7 (from XP and WHS) and I want to continue using firewire for channel changes. That means that you have to use the 32 bit version of Win - specifically I am using Win 7 Pro 32 bit.
I first tried installing the original Tim M Moore drivers and apps. Win 7 tried to automatically load drivers for the STB which I don't ever remember seeng from XP. I then downloaded the ExDeus drivers and they appeared to work.
However I could never get the Tim Moore channel.exe or channelw.exe to work to actually change channels. I had to use the new SageChanger app with the -f 4 option and it works great.
Note that on a SA3250HD the original Tim Moore drivers and apps work fine.
FWChannelProxy2 Firewire Channel Changing lightmind Hardware Support 34 07-01-2014 12:27 PM
channel changing via firewire on Rogers 4250 toony SageTV Canada 3 06-21-2010 02:45 PM
Firewire channel changing Win7 Jackal24 Hardware Support 1 05-20-2010 02:10 PM
Channel changing via Firewire showson1 Hardware Support 1 10-15-2008 02:08 PM
Firewire channel changing gjvrieze Hardware Support 4 07-07-2008 03:05 PM
