Old 03-15-2015, 12:42 PM
jvl711's Avatar
jvl711 jvl711 is offline
Interest in HDHomeRun Prime Network Encoder
Hi,
I was having some issue with SageDCT, so I decided to make my own Network Encoder for the HDHomeRun Prime. I was wondering if there is interest out there for another option to SageDCT. Let me know if there is and I will package up a beta version of what I have and release if for other people to try.
The encoder was written in Java 1.7, and only requires HDHomeRun_config.exe and ffmpeg.exe. I think it should be able to be used on Windows, Linux and Mac. I am currently using it in Windows Server 2003.
Josh
Old 03-15-2015, 12:47 PM
I am interested.
Old 03-15-2015, 12:53 PM
I would be interested also. home much drag does it put on the cpu my server is only a core duo.
Old 03-15-2015, 01:41 PM
valnar valnar is offline
I've never used SageDCT but I'd be interested. I was going to pick up a Prime shortly in hopes that the continued efforts of Sage will use it.
Client 2: HD300 on Vizio 40"
Old 03-15-2015, 03:53 PM
FriscoJohn FriscoJohn is offline
I'm interested. Appreciate your willingness to share!
Old 03-15-2015, 05:11 PM
Tiki's Avatar
Tiki Tiki is offline
Originally Posted by jvl711 View Post
Hi,
Josh
I'm curious about what issues you had with SageDCT that you were able to address with your version. Having more than one option is great, just wondering why I might want to switch.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 03-15-2015, 10:05 PM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
Will it work with a Ceton tuner as well?
Server: HP w/Intel i7-4770S CPU @ 3.10GHz , 500GB SSD, 16GB DDR3, Win 10 64-bit, 4TB of SSD for recording
SageTV: 9.2 - 64-Bit
Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels)
Client 1, 2, 3, and 4: HD200.
NAS: Synology DS220+ 8TB (Movie Storage)
Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in
Old 03-16-2015, 03:36 PM
jvl711's Avatar
How much overhead does it take?
I have seen very liitle cpu usage from the application. It utilizes ffmpeg to connect to the HDHomeRun prime and save the stream to a file. ffmpeg on my server has used less that 1% cpu with low memory overhead.
What issues have I had with SageDCT that caused me to write a new Network Encoder?
I have had a few issues with SageDCT that I was not able to resolve. Most noteably I have had to run SageDCT on a seperate box than my server since it requires upnp services, and the windows firewall to be enabled. On top of that I have had issues getting SageDCT to generate perfect streams without pixelation, studdering and audio dropout. The process that I am using to capture the stream seems to be less relient on the network capacity. I have been able to record a stream and copy a file over the network to my SageTV server without any hiccups in the recording stream. I am pretty sure the way I wrote the Network Encoder should work cross platform as well.
Will this work with the Ceton tuner?
It will not work with the Centon tuner. It is specifically designed to work with the HDHomeRun Prime. It may work with other HDHomeRun tunners as well. It releies on the HDHomeRun_config application to change channels and to start the steam to ffmpeg.
I plan to clean up the code this week. I want to add some more logging and write some instructions for use. Then I will put something out in beta next week.
Old 03-16-2015, 03:58 PM
mgpaulus mgpaulus is offline
I would be interested in a beta as well.
Old 03-16-2015, 04:30 PM
rboeser rboeser is offline
I'm interested.
I currently use SageDCT with few if any problems. I could complain but I'm limping along with my system that has not been touched in almost 4 years. Just happy to still be using SageTV.
I can not find anything remotely close to SageTV, I've bought almost every extender that supposedly streamed from a network server. Not one has been satisfactory.
I could help with beta testing if you need some feedback. I have a brand new HD Prime sitting here with the cable card ready to go.
Let me know if I can help.
Rboeser
Old 03-16-2015, 05:09 PM
I run Sage on a Win7 box with the HDHR drivers for a regular HDHR Dual. Will I be able to run this on the same box?
Old 03-16-2015, 05:50 PM
mikejaner's Avatar
I wouldn't mind testing too. I jut bought a second Prime on sale on Woot, and would like to put it to good use. I am also seeing pixelation on some channels and am wondering now if this would make a difference.
Mike Janer
SageTV HD300 Extender X2
Old 03-16-2015, 08:54 PM
mistergq's Avatar
mistergq mistergq is offline
Media Server: Win 7 Home (32 bit), GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard, Intel Core 2 Quad Q9505 Yorkfield 2.83GHz, 4 GB Ram, Geforce 9600 GT PCI-E, 1x HD PVR, HD homerun (2x for OTA, 1x for FIOS QAM), 1 x HD Homerun Prime with cablecard from FIOS.
Client: Windows 10 Pro
Media Extenders: HD-200 x 3, HD-200 x 2
Old 03-17-2015, 06:32 AM
With any luck, and if you are interested, we'd be able to port what you've made into the core sage system - once it is made available.
Out of curiosity, have to attempted to do any live transcoding with your ffmpeg process to convert the MPEG2 to H.264, instead of a straight stream dump?
Old 03-17-2015, 06:48 AM
Have you tested it with linux? or are you just thinking it should work? Regardless I'm interested too. SageDCT occasionally gives me borked recordings (unable to start on back to back recordings with the same tuner i think... so I'm either missing the first couple minutes or the entire recording).
Check out TVExplorer
Old 03-17-2015, 01:51 PM
mayamaniac's Avatar
I'm very interested. Babgvant's SageDCT was great but wasn't perfect, plus he hasn't updated it in a long while.
Mayamaniac
Old 03-17-2015, 02:48 PM
rochurch rochurch is offline
If it could clear the copy once flag that Time Warner puts on almost all of their channels that would be great. I only want to copy once and keep it here in my home network for private viewing. I have a cable box and an HDHR to do one channel at a time. I don't want 3 cable boxes and 3 HDHR's. I have a Silicondust Prime with a cable card in it but it does me no good since it only works with Windows Media Center.
Old 03-17-2015, 04:27 PM
That's not something that will work without getting the system CableLabs certified - not something that Sage ever looked into, because Sage had put their bet on AllVid (they were a founding member of the AllVid alliance). Technically, the CableLabs specs say that you CAN retransmit protected content over unprotected channels, if it's resolution is dropped - so it would potentially be possible to make a protected path from HDHR -> CableLabs certified driver -> Degraded unprotected output - but the time and cost to get it certified is going to be better spent just using an HD-PVR for those channels.
Old 03-17-2015, 05:29 PM
mikejaner's Avatar
Yes, this would be an awesome feature!
Mike Janer
Old 03-17-2015, 05:56 PM
jvl711's Avatar
I have not tested it in Linux but I have no reason to believe it would not work. It's only requirements are:
Java, HDHomeRun_config and ffmpeg. All of these items have linux ports.
Prime Encoder Script checkbin SageTV Linux 14 03-22-2015 07:50 AM
SageTV as a network encoder / recording on network encoder works, not from server perfessor101 SageTV Software 0 06-21-2014 05:59 AM
Ubuntu + HDHomerunPrime + Prime Encoder matt91 SageTV Linux 2 03-23-2014 03:46 PM
HDHomerun Prime? cenwesi Hardware Support 26 04-19-2011 05:40 PM
