Old 10-31-2019, 03:56 AM
fre fre is offline
SageTV + hauppauge QuadHD + DVB-C
Dear Community,
Iím trying to get SageTV to work with my Hauppage QuadHD Tuner, but I canít setup it up for DVB-C.
As you can see, I have 2 of them (screenshot 1)
After selecting the first option, the next screen is determining the signal (screenshot 2)
After it has finished determining the broadcast standard, it shows only DVB-T (screenshot 3).
On both of my cards, cable (digital) TV is connected.
I can not see any option to select DVB-C instead of the DVB-T in the screenshot (3) above. When I proceed with DVB-T, of course SageTv can't find any channels.
I do not have any problems with mediaportal or Nextpvr to find DVB-C. Iíve uninstalled both of these programs so SageTv can freely use both tuner cards, but no luckÖ
Any ideas how I can let SageTv recognize the signal as DVB-C instead of DVB-T?
Old 11-01-2019, 04:15 PM
SHS's Avatar
SHS SHS is offline
Originally Posted by fre View Post
Dear Community,
Dose WinTV work
Old 11-06-2019, 11:43 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
What is the model of the card?
If using Windows, what does device manager show as the description?
John
Old 11-07-2019, 02:58 AM
https://www.linuxtv.org/wiki/index.p...8DVB-T/T2/C%29
Which os are you using for your server?
I am running Mx Linux 19 with a Quad tuner atsc version. & have successfully ran win 10 as well. Not sure on the driver situation for win 10 with dvb drivers.
Did you also install the required firmware file?
The hauppauge devices require 2 parts;
1 driver file
2 firmware file
In linux you can try testing with kaffeine media player ( the linux equivalent of win tv application)
In linux kernel 4.19 & later the necessary components are present. Not sure about all versions of earlier kernels ( depends on if the mainline edits were incorporated)
Also read :
http://www.hauppauge.com/pages/suppo...ort_linux.html where it mentions needing to install the firmware.
https://www.linuxtv.org/wiki/index.php/Hauppauge
http://www.hauppauge.co.uk/site/prod...ta_quadhd.html
Note: not all cable TV networks send clear DVB-C channels. Please check with your local cable operator for the availability of clear digital cable TV
***https://github.com/tsduck/tsduck/issues/229 Here is someone else attempting to access dvb-c tuning on their setup. The issue seems to be incomplete hardware setup ie drivers.
Old 11-08-2019, 11:48 PM
JREkiwi's Avatar
I have a new build of DShowCapture.dll which I'm testing that may resolve your issue if you're happy to give it a try
64bit
32bit
John
Last edited by JREkiwi; 11-11-2019 at 01:56 AM. Reason: Change links to latest builds
Hauppauge WinTV-quadHD SHS Hardware Support 188 12-26-2021 11:01 AM
WinTV-quadHD USB SHS Hardware Support 23 03-12-2020 05:31 PM
Hauppauge QuadHD tuner. T1 access all chan. T2,3,4 have problems with some channels SteveP Hardware Support 4 08-11-2019 04:06 PM
Hauppauge WinTV-quadHD Galaxysurfer Hardware Support 3 10-06-2017 07:28 PM
current status of Hauppauge WinTV-quadHD pci board Galaxysurfer Hardware Support 6 10-31-2016 04:03 PM
