Firestick 4k- no video from Colossus 2?
Getting sound only, what combination of setup options do I need for the Firestick to be able to show video that originates from a pcie Colossus 2 usng HDMI? Does the mini client need IJK or EXO? Codecs? Does the colossus need to be outputtng differently? Been a long time since i set up a new piece of hardware!
[size=1]Current Server:V9 UNRAID Docker, SuperMicro x9dri-LNF4+, 32 GB ECC, 2x Xeon e5-2660v2, storage array 6TB, 2 Dish r5000HD tuners, 1 HDHomerun Quatro, 1 HDHomerun Extend 4 Nvidia Shield TVs with Miniclient |
Changed to software decoders and IJK, now have video but its slighty choppy and seems to drop frames. Is there a specific decoder I should use? I thought the firestick had hardware decoding?
In my 13 years with sagetv i have never understood codecs so there very well may be obvious answers, but searches aren't turning anything up
First, be sure to use the newer "forked" version of the SageTV Mini Client - it's actually called "SageTV Android Client" now in the Amazon store.
Check out this thread for more information: https://forums.sagetv.com/forums/showthread.php?t=66405 Second, are you using OpenDTC to record the stream? If not (probably using SageDTC instead), switching to OpenDTC might make it work out of the box. OpenDTC seems to write data to the containers correctly when other apps don't. This makes a difference when trying to play back material using the "mini client" devices.
i7-6700 server with about 10tb of space currently SageTV v9 (64bit) Ceton InfiniTV ETH 6 cable card tuner (Spectrum cable) OpenDCT HD-300 HD Extenders (hooked to my whole-house A/V system for synched playback on multiple TVs - great during a Superbowl party) Amazon Firestick 4k and Nvidia Shield using the MiniClient Using CQC to control it all Last edited by sic0048; 09-04-2020 at 09:00 AM. |
Has your firmware upgraded to 6.2.7.3 yet? There were major issues with h264 1080i on the FTV 4K before this current release.
Martin |
Miniclient+OTA - firestick looks better than Nvidia Shield? | Telecore | SageTV Clients Development | 10 | 03-01-2020 05:36 PM |
FireStick 4k + Flirc + Miniclient | Telecore | SageTV Clients Development | 0 | 09-24-2019 01:10 PM |
Colossus + DTA | fefelover | Hardware Support | 7 | 12-25-2013 01:25 PM |
HD PVR or Colossus? | twollman | Hardware Support | 20 | 03-23-2011 01:29 PM |
Colossus not getting EPG | Crunch | SageTV EPG Service | 2 | 03-10-2011 12:45 PM |
