Old 11-20-2016, 07:42 PM
SHS's Avatar
SHS SHS is offline
Ubuntu 64 Install
Any post a reg install doc for SageTV Server Install 64x with latest ver with out all using the GitHub from stuckless ?.
Old 11-21-2016, 05:15 AM
Not exactly sure what you are after... to just "install" sagetv, you can download the BinTray deb package and then install it, and you are done.
Setting up IR blasting and comskip, etc, these are all somewhat tedious, and not really a part of the install, but rather the post installation configuration (if you need/want them).
You can also run the Docker image directly on ubuntu and it would come with the added benefit of having comskip configured. Configuring IR blasting would still require some effect.
Old 11-21-2016, 09:49 AM
SHS's Avatar
SHS SHS is offline
Never mind I guest I miss the v2 (Basic Linux V9 Build and Walkthrough - V2) as ver 1 from SageWizdom was jump all over place
So from look of it look like I have fellow step3, 5 thur 8 and just update commands to ref the latest ver of sagetv deb
I just for test WinTV-quadHD
Old 11-21-2016, 09:54 AM
matt91's Avatar
matt91 matt91 is offline
I realize this isn't really a sage question, but what's the (estimated) performance hit for this? Running docker + sage must consume more resources than just running sage alone. Is it generally a small hit?
Old 11-21-2016, 10:21 AM
In short, you likely can't tell the difference... but here's a much better explained response
http://stackoverflow.com/questions/2...cker-container
Old 05-31-2017, 06:02 PM
ThePaladinTech's Avatar
ThePaladinTech ThePaladinTech is offline
Just saw this... This may be the solution for my brother as getting unraid isn't an option.
Could you help me with some of the commands? from here: https://forums.sagetv.com/forums/showthread.php?t=63165
docker run -d --name sagetv-server \ <- so that names it so it's not some random named container right?
-v /home/seans/unRAID/mnt/user/sagemedia:/var/media \
-v /home/seans/unRAID/mnt/user/mediaext:/var/mediaext \
-v /home/seans/unRAID/mnt/user/apps/sagetv3:/opt/sagetv \
-v /home/seans/unRAID:/unraid \
--net host \
--env PUID=1000 \
--env PGID=1000 \
--env VIDEO_GUID=19 \
--env OPT_GENTUNER=Y \
--env OPT_COMMANDIR=Y \
--env OPT_COMSKIP=Y \
--env JAVA_MEM_MB=768 \
--env VERSION=latest \
--env OPT_SETPERMS=Y \
--privileged \ <- This gives it more access to the system? for remote access as far as I can tell?
-t -i stuckless/sagetv-server-java8
I'm most puzzled by the -v command I bolded - what would the equivelent be for ubuntu? btw the ubuntu user is 'sagetv9'
Thanks all
Edit: presently looking through the 11 page post i referenced, maybe it's in there
(current) SageServer: SageTV Open Source V9 - Virtual Ubuntu on Win10 HyperV MSI 970A-G46, AMD FX-8370 , SD Prime via OpenDCT, Donater ComSkip
Clients: HD-200, Nexus Player w/ Android miniclient
Storage: "nas" 16 drive Win10 w/ DrivePool running Plex, Emby, & SD PVR
Retired - Hava, MediaMVP, HD-100, HD-PVR, HVR-2250, Ceton InfiniTV4, Original (white) HDHomeRun Died - HD-100, HD-300
Old 06-01-2017, 02:11 AM
the -v option is used to map an actual host folder to a folder within the container. What that bolded one does, is map actual folder /home/seans/unRAID to /unraid inside the container, so sagetv could find any file under the /home/seans/unRAID folder beneath it's own /unraid folder... Technically, the only volume mapping (-v option) that would be required for sagetv would be mapping the server folder (/opt/sagetv) and a share used to access recording and import folder locations (/var/media).
Internally, I believe sage defaults to the following paths:
/opt/sagetv -> SageTV main folder
/var/media/tv -> SageTV Recordings folder
/var/media/videos -> Video Import folder
/var/media/pictures -> Picture Import folder
/var/media/music -> Music Import folder
Old 06-01-2017, 04:50 AM
You can ingnore -v unraid option since I use that to better mimic what an unraid filesystem looks like when I doing testing.
--priviledged is used so that it can expose the necessary ports with mapping them (it is required)
And yeah, that first bolded part is so that you give it a good name which makes it easier if you need to run docker logs etc.
HOWTO: Install SageTV PlaceShifter on Ubuntu 10.10 Desktop 32-Bit bcjenkins SageTV Linux 5 10-26-2012 09:42 AM
Moving sage install to Ubuntu 11.10 amd64. kbyrd SageTV Linux 5 11-14-2011 08:43 AM
Install fails w/ ubuntu thegodfaza SageTV Linux 2 01-10-2010 09:19 AM
64 bit Ubuntu install problem. marcusjohn SageTV Linux 0 10-04-2008 12:53 AM
Install Sage on 64bit Ubuntu (7.10) uggie SageTV Linux 2 11-13-2007 06:04 AM
