Old 01-25-2017, 01:26 PM
matt91's Avatar
matt91 matt91 is offline
problem tuning single channel with OpenDCT Docker
I have been happily running sage and opendct on linux (baremetal Ubuntu 14.04) but thought i'd try out a docker install. I have an UNRaid server already running, so that was my testbench. I was using the "CraziFuzzy/opendct-docker" and the sage docker from stuckless.
Install and setup went fine, but i discovered that one of my channels later failed to tune. I recall that this specific channel worked on Day 1, but was no longer there on Day 2. Here are the opendct and sagetv logs for 8:40AM to 8:43AM when I was tried to tune that channel.
Anything in here point to a smoking gun?
(the log shows a recording for "Today" which wasn't working, and then a manual recording on that same channel [/var/media/19578_804_0123_0841-0.ts] since I wanted to force OpenDCT to try a second tuner.)
I should note that other channels did work. I do have log entries for a later show that did work, but this NBC channel still failed to tune, even after a few resets of my HDHR3-CC and the docker instances.
thanks
matt
edit: I was able to tune and view the channel via the Silicon Dust 'hdhomerun-config' program, so the stream from Comcast seemed to be OK.
Old 01-25-2017, 01:58 PM
EnterNoEscape's Avatar
I should note that other channels did work. I do have log entries for a later show that did work, but this NBC channel still failed to tune, even after a few resets of HD HomeRun and the docker instances.
thanks
matt
It looks like the media server remuxer was unable determine the format of the container. The exact reason can't be determined from the SageTV logs. You will want to add a file named NATIVE_LOG.ENABLE to your SageTV folder, then restart SageTV. SageTV will then create a file called Native.log and that should give us a better idea of what's happening.
Problem with a single channel bmac.to Hardware Support 9 09-06-2011 10:30 AM
Problem tuning a channel gmartell69 Hardware Support 0 03-13-2007 02:08 PM
channel tuning problem gand SageTV Software 0 11-03-2006 12:53 PM
Problem with channel tuning on PVR150 BrandonMills SageTV Software 1 07-13-2006 02:54 PM
Problem tuning one channel Wheemer SageTV Software 10 02-15-2005 12:51 PM
