Old 06-20-2017, 04:14 PM
unRAID Share Split Level Recommendation?
Any recommendations on the split level that should be used for the SageTV docker for ripped DVDs? Here is an example of a ripped DVD structure on my server (and probably many other people's servers):
Windows:
\\Tower\sagemedia\videos\Jason Bourne\VIDEO_TS
unRAID:
/mnt/user/sagemedia/videos/Jason Bourne/VIDEO_TS
So minimally, all of the files contained within the VIDEO_TS folder should be stored on the same physical drive within the array, to avoid pauses during playback. Would split level four or five be best?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i3-7100T CPU, 16GB Memory, unRAID 6.3.2, SageTV & OpenDCT Dockers
Old 06-21-2017, 01:45 AM
3 or 4 would probably be fine - though the better option is to just get rid of the VIDEO_TS format, and go with MKV's and not worry about splits.. ;-)
Old 06-21-2017, 09:50 AM
matt91's Avatar
matt91 matt91 is offline
//off-topic//
i'm trying to remember when i last ripped a DVD to my hard drive. It's all streaming now! (and ball-bearings!)
Old 06-21-2017, 10:15 AM
Boy, this brings back memories of the iso vs. vob discussion in this forum quite a few years back, I ended up going the vob route. I assume that going the MKV route would result in a single file? Also, can MKV support full-disc copies of DVD, including the interactive menus? If so, what tool would I use to convert my ripped full-disc DVDs to MKVs?
Old 06-21-2017, 04:37 PM
Technically, yes, MKV does support multiple videos per file, with a menu system - but I honestly haven't ever seen a player that fully supported the things the MKV format can do, nor have I seen a program that could convert he menus into the MKV file. MKV was a pretty ambitious format, and only a fraction of the spec is ever really used. Kind of a shame, really - it has some great features that would really make it very well suited to DVR recording and playback - but the mp2ts container is just too 'standard'.
Old 06-21-2017, 06:50 PM
Anybody know if the unRAID / SageTV docker combination supports .iso playback?
Old 06-21-2017, 08:21 PM
To answer my own question, it apparently does. A follow-up question, though: is there a way to prevent the .iso file extension from displaying in SageTV? For example, if I go to the Videos / DVD/BD screen in SageTV, I see "Jason Bourne.iso" instead of just "Jason Bourne". Any way to prevent the .iso from being displayed?
Old 06-22-2017, 01:23 AM
I think that means it doesn't have actual metadata for that file - so it just displays the filename instead of the mediatitle. DO you have Phoenix Core Services installed? You could use CMT or BMT to lookup and have Phoenix download the information if it is missing, and it SHOULD work (can't verify, as I don't have any ISO's).
Old 06-22-2017, 05:44 AM
At a practical level, yes, MKV results in a single file (with chapters, multiple audio/subtitle tracks, etc), but does not support full DVD functionality.
Migrating from a single RecordedTV share to that same share plus a local drive? PeteCress SageTV Software 1 06-05-2017 03:14 AM
Block Level vs File Level Storage Taddeusz SageTV Github Development 4 02-03-2016 03:09 PM
UnRaid + User Level Security + Extender Quick Question.. ChuckSchick Hardware Support 1 03-26-2010 10:09 AM
user share question for unRaid users lovingHDTV Hardware Support 4 12-10-2009 09:07 AM
Split backend dagar SageTV Software 10 07-06-2005 06:18 PM
