Old 07-19-2017, 06:32 PM
Eternal Eternal is offline
favorites bug after changing lineups
Favorites dont record after changing lineups.
The favorites are still there but none of the upcoming are marked as record
It fixes itself if you disable and reenable the favorite or delete it and readd it
Old 07-19-2017, 07:33 PM
It won't rerun your schedule until it is done with the EPG update. On day one, that update can take a long time. altering a favorite is triggering the scheduler early.
Old 07-19-2017, 07:59 PM
matt91's Avatar
matt91 matt91 is offline
I also found that nothing was populated in my scheduled recordings even after the full EPG downloaded. Once I restarted Sage, it immediately computed the recording schedule.
Old 07-20-2017, 05:13 AM
EnterNoEscape's Avatar
It's not instant. There's a process that used to take over a day for some people that kicks off after the update completes that finds your favorites. You should have seen something after about 30 minutes, but restarting SageTV makes that process run in the foreground, so it happens a lot faster.
Can I have two lineups on one device? ASegredo SageTV EPG Service 0 07-27-2016 07:43 PM
Two lineups on the same tuner? ASegredo SageTV EPG Service 1 01-18-2012 06:32 PM
problems with favorites and changing channels chrysek SageTV Beta Test Software 0 04-06-2006 09:28 AM
2 Receivers, Different Lineups m0ng00se30 SageTV Software 9 12-28-2004 11:38 AM
Zap2It Lineups? m0ng00se30 SageTV EPG Service 0 01-04-2004 08:44 PM
