Old 08-14-2009, 12:52 AM
BK_mss BK_mss is offline
can't play youtube online content?
I just installed my new HD200, so my total experience is only about 2hrs and this is my first post. It's plugged into my LAN through a netgear GS108T switch and accessing media from an HP MediaSmart LX195 server. Output is through the component ports. Setup was seamless with the default settings, and I followed the instructions and updated the firmware as a first step. Overall I am very impressed so far! I also purchased SageTV server software, but I have not yet installed it and I'm initially using the HD200 just in standalone mode.
One issue I'm having is that I cannot play YouTube videos in the online content area. I can see the thumbnails and categories and get the lists, but when I attempt to play a specific video I get an error "unable to determine the video file to download."
In the case of many Google videos, the error is "Video does not have MPEG4, FLV or AVI file type."
Other online content seems to work fine for me.
Is there a solution for the youtube videos??
BK
Old 08-14-2009, 04:13 AM
Did you upgrade the firmware on the hd200 to the latest?
Old 08-14-2009, 09:54 AM
Yep. I don't have the version number handy, but I updated the firmware as one of the first steps per the box insert, and then later I ran the "check" function again and it indicated that I was up to date.
BK
Old 08-14-2009, 11:11 AM
Have you checked those exact same vids on the YouTube page? I have seen this happen quite often, and usually it's a result of the vids being removed by YouTube (usually DMCA violations and such). They still show up on video searches, just cannot be played. I think this is usually the issue.
Old 08-14-2009, 11:38 AM
Good point - I'll give that a try to confirm. I initially tried about 15 youtube videos through the HD200 and all of them failed with the same message.
BK
Old 08-14-2009, 04:45 PM
shill shill is offline
I've got the same problem.. Just hooked up my brand new HD-200's and got everything working off the server, upgraded to the latest firmware, and no love from youtube at all.
Old 08-14-2009, 04:53 PM
carlgar carlgar is offline
I also saw this issue today. My impression is that there is probably someone missing from the configuration telling Sage how to play or what types of files. Some of the messages I saw indicate that the video was not one of 2 or 3 types. I very seldom view on-line videos so I did not look into it. I was just curious about it.
I also encountered one video that said it needed to be downloaded before it would play. It stopped at 21% downloaded. I suspect the HD200 did not have enough memory to play it.
I did find some on-line videos that played fine.
Old 08-14-2009, 04:55 PM
I've been seeing it for the last week or so with my trial client that I was playing with while waiting for the HD-200's to arrive.
Old 08-14-2009, 06:06 PM
I take some comfort in the fact that I am not alone in this!
BK
Old 08-14-2009, 11:54 PM
Setup the SageTV add-in on my WHS server...same issue with much of the online content, particularly youtube.
BK
Old 08-15-2009, 08:16 AM
lfilomeno lfilomeno is offline
Online Services (youtube, Google) not Playing Online Videos Anymore
2 days ago, I tried to show off my system to a friend by downloading a couple of Online HD videos from Youtube. The HD 200 shows the video list after download using my search criteria. If does not matter which one I pick, I got the "ring of death" in the middle and very quick got the message "unable to determine the video file to download". I usually got the "video does not have an mpeg4, flv, or avi file type" on some videos but even the ones I use to watch online now are giving me this error! MY server is running version 6.5.9.204, java version 1.6.0_10 heap size 265/266. Extender is on firmware version 20090814 1. I can watch the online videos on the server via the web browser either in youtube and/or google. Thanks in advance fro all the support.
* merged *
Old 08-15-2009, 11:59 AM
davidjade davidjade is offline
I just started seeing this as well. It has been working fine until the last few days. I now cannot play any YouTube videos at all. I have changed nothing on my setup. It just stopped working.
Old 08-15-2009, 01:47 PM
TakeFlight's Avatar
TakeFlight TakeFlight is offline
Same here. Although, a few days ago "some" videos would play, but most would not. Now it seems none will play. I'm running the latest version of SageTV and the latest firmware on my HD200.
UPDATE: Apparently some videos do still play but they are few and far between.
Pegasus - SageTV/HomeSeer Server: Core2Duo 1.8GHz, 1GB, 1.5TB RAID5, 2.25TB RAID5, Radeon X1050, (2) Hauppauge PVR250 (only used for security cameras now), SiliconDust HDHomeRun, Hauppauge HD-PVR, WinXP Pro
Prometheus - SageTV Client: Core2Duo 2.66GHz, 1GB, 500GB, GeForce 8400GS, WinXP Pro, 848x480 to InFocus SP4805 projector on a 78" screen
HD Theater (HD200) connected via HDMI to Panasonic TH-42PX60U 42" plasma
web server plugin | 2 MediaMVP Extenders | FiOS TV
Old 08-15-2009, 04:21 PM
I agree with take flight. I opened a thread on the SageTV media extender forum early this morning. Same situation as other users above. I have made no changes to the system and just upgraded to the newer firmware today to no avail. the kids use to love this feature!
Old 08-15-2009, 11:05 PM
bclenney bclenney is offline
I have the same issue right on my SageTV media player. I'm not using server mode, no clients, no extenders. Things that used to play I now get these errors. I'm using the latest version of SageTV.
Old 08-16-2009, 07:13 AM
We know about the issue & will be looking into the cause & solution.
Old 08-17-2009, 03:56 AM
reeven reeven is offline
same problem here, sagetv mc, tv-tuner.
For youtube 18 year content you need to sign in youtube ?
How Sage TV play these video with sexual content for exemple? You need to log in or something?
Old 08-17-2009, 09:04 AM
Thanks OPUS4 for looking into this issue.
Old 08-17-2009, 10:31 PM
An online video properties file update has been created which fixes this issue, or at least it works on my system.
Depending on when SageTV last checked for an update on your system, it could be downloaded to your PC any time over the next 24 hours. (SageTV checks for an update once per day after you jump to the Main Menu.)
Old 08-18-2009, 12:08 AM
TakeFlight's Avatar
Working great so far. Thanks!
youtube
"video does not have MPEG4, flv or avi file type" slimyosra SageTV Software 10 12-17-2008 12:58 AM
RE: "video does not have MPEG4, flv or avi file type" toony SageTV Software 1 12-11-2008 06:03 PM
"Play other video file" missing in 6.3.8 brewston SageMC Custom Interface 3 10-27-2008 09:00 AM
How to recognize "other" video file types wkoperwhats SageTV Software 2 03-04-2007 06:25 PM
Pure Video "Smart Mode" Polypro SageTV Software 4 12-09-2005 05:13 PM
