Old 01-20-2019, 09:31 PM
Beaker's Avatar
Beaker Beaker is offline
Exclamation YouTube(2015) Help
I messed up my YouTube install and would like some help.
It was working fine before I uninstalled the old WU weather plugin, installed the new NWS plugin, and updated Java (since it was nagging). Unwisely, I did all of these at the same time.
Now I have the YouTube plugin half working - it is in the menu structure. I have the ability to log out and in within the plugin. I can see a list of favorite channels when hovering. But nothing requiring data from the internet responds correctly - it flashes the Gathering Information popup, then in less than a second switches to There Is Nothing To Display with a Close button.
I have rebooted the computer, uninstalled and reinstalled the YouTube plugin restarting in between, uninstalled/reinstalled Java. Nothing I have tried remedied the problem. I don't know where else to look or what to try and I would be grateful for any help.
Windows 10 running v9.1.9.778
Java v1.8.0_201
As a side note, is it possible to have YouTube(2015) and Weather show up in the Online screen, not just in the popover menu structure?
"Worry does not empty tomorrow of its sorrow; it empties today of its strength." Corrie Ten Boom
Core-i5 6600k
16GB RAM
Hauppauge WinTV-QuadHD
Win10
Old 01-21-2019, 06:41 AM
Java v1.8.0_201
Thanks for the warning. I haven't been able to install the latest Java even though it keeps nagging.
ASRock B450M Pro4 AM4 mATX AMD Motherboard, AMD Ryzen 5 2600 3.4GHz, Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-3200, EVGA GT 1030SC, WD - Black SN750 NVMe SSD 250GB, 1x WD80EFAX 8TB, 2x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-quadHD USB, Windows 10 64bit
Old 01-21-2019, 09:11 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Java v1.8.0_201
Post a logfile please.
Old 01-21-2019, 05:14 PM
Beaker's Avatar
I'm not wise in the ways of log files, but I'll take a stab that you mean sagetv_0.txt. I restarted the server service and client to generate this fresh.
Core-i5 6600k
16GB RAM
Win10
Old 01-23-2019, 06:58 PM
Beaker's Avatar
In further attempt to repair this, I have uninstalled the latest Java Update (202?) and installed an earlier update (191). It didn't fix this problem.
I uninstalled YouTube(2015) and all it's related plugins and restarted Sage. I reinstalled YouTube(2015) and the new Java didn't solve anything. The problem persists.
Any advice?
Core-i5 6600k
16GB RAM
Win10
Old 01-23-2019, 09:59 PM
egeller egeller is offline
Any advice?
Good news, for you. I am just now seeing similar symptoms, so you are not alone. Something strange is going on.
It is late. I will do a full test tomorrow, assuming I can reproduce the same symptoms, and post logs.
@tmiranda - Do you want logs here or in the plugin's thread?
SageTV Extender:3x HD200 1x HD300
Sage TV: 9.2.1, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, YouTube2015, Playon
All in lovely Drexel Hill, PA
Old 01-24-2019, 05:25 AM
tmiranda's Avatar
In the main thread please.
Old 01-24-2019, 06:26 AM
Beaker's Avatar
Yay! I'm so glad you added this!...
Uh... I mean, [ahem] so sorry for your troubles.
Core-i5 6600k
16GB RAM
Win10
Old 01-24-2019, 10:51 AM
Cannot reproduce problem yet - No logs for now on Beaker issue
Unfortunately, after restarting SageTV, I cannot reproduce the problem this morning. Youtube is now behaving normally for me, in that the list of videos is coming back and showing. Yesterday, I was not getting the list of videos when I searched. I will need to wait until I see the issue again and grab the logs at the time it occurs.
I am still seeing the issue, reported in the plugin's thread, with showing videos and halting. Certain videos halt, while the sound and time index continue. I posted reports from MediaInfo there and will post today's log in the plugin thread, with notes on how I reproduced that issue.
Old 01-25-2019, 03:28 PM
Beaker's Avatar
I have forced the error and located what I think is the result in the log file. You can see from this that I had logged out from YouTube (within the plugin) and this snippet starts with me logging back in. Following that I clicked My YouTube Channel.
Fri 1/25 15:14:54.601 [Timer-1@1636e3a] YT: FavoriteManager: Looking for new Favorites.
Fri 1/25 15:14:54.606 [Timer-1@1636e3a] YT: FavoriteManager: Getting Subscribed channels.
Fri 1/25 15:14:54.612 [Timer-1@1636e3a] YT: DeviceAuth.getUsableAccessToken: Returned valid access code: ya29.GlucBgkPNPLz1q8a44Rz-OKUJ9MdK3Eb7RTUchxlHGP0WvlNbQOporbP6nv6mQIem6q2cjL6Yqx0UGe6cLSza-xnGkalXZn-VylzXHg7AyttM5fTBBoKIy28IMR_
Fri 1/25 15:14:54.619 [Timer-1@1636e3a] YT: DeviceAuth.getUsableAccessToken: Returned valid access code: ya29.GlucBgkPNPLz1q8a44Rz-OKUJ9MdK3Eb7RTUchxlHGP0WvlNbQOporbP6nv6mQIem6q2cjL6Yqx0UGe6cLSza-xnGkalXZn-VylzXHg7AyttM5fTBBoKIy28IMR_
Fri 1/25 15:14:54.626 [Timer-1@1636e3a] YT: Subscriptions.getSubscriptionsForAuthorizedUser: Size of items 0
Fri 1/25 15:14:54.631 [Timer-1@1636e3a] YT: FavoriteManager: Terminating due to exception null
l
Is there some way to get a more detailed exception error?
Core-i5 6600k
16GB RAM
Win10
Old 01-25-2019, 04:42 PM
Beaker's Avatar
Also found this in the sagetvclient_0.log... It's long so I've attached the file for review.
Core-i5 6600k
16GB RAM
Win10
Old 01-27-2019, 06:37 AM
Beaker's Avatar
Fixed
For anyone following this thread, a resolution has been achieved. Says tmiranda in a PM...
"I found (and fixed) an error in one of the plugin manifests that I think is the cause of your problem. Try uninstalling YoutTube and NWS. (Both, that is important.) Then reinstalling YouTube."
That didn't quite do it. I had to uninstall all dependent libraries, allow the UI and Server to restart, then reinstall. Now both YouTube(2015) and the NWS Weather (still in beta at time of writing) are working.
Thanks to tmiranda for making and supporting these plugins. I think in this house they are used more than the core functions of SageTV.
Core-i5 6600k
16GB RAM
Win10
Old 01-27-2019, 07:12 AM
tmiranda's Avatar
Thanks. Yes, you will need to manually uninstall all of the dependent plugins and specifically all of the "jackson" libraries.
youtube
PlugIn: YouTube (2015) tmiranda SageTV v7 Customizations 816 03-26-2020 06:41 AM
Plugin YouTube (2015) - max. number of videos per channel ? wubdich SageTV v9 Customizations 7 03-22-2017 07:08 PM
2015 Teddy Bear Toss tvmaster2 The SageTV Community 1 12-07-2015 02:59 PM
FiOS DRM Channels (11/2015) mayamaniac Hardware Support 1 11-18-2015 02:13 AM
Will 2015 leap second effect SageTV? Paul H SageTV Software 10 01-16-2015 07:43 AM
