General Discussion General discussion about SageTV and related companies, products, and technologies. |
Just Learned of SAGETV and have some questions.
I am a TIVO user. My wife and I are building a home and I was wanting to network all TVs for TIVO viewing when I discovered SAGE TV and it looks like the way to go. I have a few questions (some of which will probably sound stupid). Any responses would be most appreciated...
1. Is the playback quality good (i.e. close to live TV)? Does playback look good on a standard TV? 2. It appears that HDTV can only be recorded from OTA. Is it not possible to record HD channels received from cable, DISH Network or DirectTV? 3. In browsing the forum, I often see mention of client-server. Will I need two computers for SAGETV to service my home reliably? 4. Assuming I have to get my HDTV via OTA, I assume it is possible to wire that into a HDTV turner on my computer, and then have say Dish Network wired into another turner on my compter for my other channels. Is that the way that would work? 5. With TIVO, if you leave a show in the middle, and go watch another show, when you return to show #1, it is right where you left. What about with SAGETV? Does it work similarly, or if you leave a show, and return does it start back at the beginning? 6. If I decide to just forget SAGETV, do any of you know of a stand alone HDTV DVR available in the U.S.? 7. As for as the networking, is just ethernet cable from room to room all that is necessary to carry quality SAGETV signals through out the house? Thanks. |
I have no complaints about picture quality. Quote:
I've long since moved my server to the basement in a corner and have a small form factor that resembles a component in my entertainment center and acts as a client. I think this is much better. I can and do standby that machine at night and the server keeps chugging. My server runs for months at a time 24/7 with 3 tuners and nearly a terabyte of storage. I do have a wife, btw, so I can attest to Sage's high WAF. I also keep an old P3-500 laptop in my daughter's playroom connected to a 19" monitor, my main laptop, and my desktop in my den all run the Sage client. My main laptop uses wireless g and worked great! Quote:
My TV and main desktop are both wired and the laptops are wireless. Good luck! I don't think you'll be sorry. |
![]() If you have standalone Tivo (not a DirecTivo), then depending on your displays and how you setup your system Sage can be every bit as good, if not better. Actually the same is true of a DirecTivo, but it gets kind of expensive to match the DTivo's direct digital recording capability. Quote:
![]() Quote:
Reliability really doesn't have anything to do with numbers, it comes down to well chosen components, and careful install, dedicated is better. Quote:
computer fan/drive noise is an issue if you put the server in the living space.
Mine is behind the TV cabinet - audible but we tolerate it. Too costly to get a truly quiet PC. You can of course use a media player box (fanless) networked to a server in the closet/garage. Quality, for me, is OK but less than Std Def TV for S-Video out from PC - due to re-encoding by the video card. I suppose a capture card with a hardware DE-coder or a media player box would have better quality. I went Sage for cost and customizability reasons. It's acceptable. |
Thanks for the replies. So, if I put the computer in a closet (and have the signals: HDTV OTA, Dish Network etc, come into the closet), would the easiet way to distribute SAGETV to the different TVs be the SAGETV Extender (buying one for each TV in the house)? Or do I need to do something else?
Though storage is something that's very hard to deal with. Quote:
In fact, I'm debating building a new client with a true small form factor and converting my current ATX into my new desktop. |
you could run an S-video cable from the server in a closet (figuratively speaking) to the TV. I've used really long cables with no visible degredation.
I beg to differ re a scratch-built quiet PC is no more than a noisy one... - I have the most quiet CPU fan that can be had. - Really quiet PS fan - No case fan - Western Digital IDE 250GB drive is TERRIBLE about noise. I tried two. I couldn't use it, sounded like a dentist's drill - despite PC magazine's rave review. - My 160G and 180G WD drives are OK. - Most quiet drive is a 180G in a USB2 enclosure sitting on a foam mousepad I read the many web pages about ways to quiet drives. Costly exotic vibration damping foam. Heat problems. Someday I'll move the server to the garage where it belongs. Can't get an S-Video cable to TV from there due to the way this home is built. |
http://forums.sagetv.com/forums/show...ght=antec+p180
And notice I made a distinction between "quiet" and "silent". My workstation (linked) is definitely quiet (even with a 10k WD Raptor) with no exotic parts, just carefully chosen ones (heck it's the stock AMD HSF). My HTPC is essentially silent, but took a bit more exotic methods (Antec Phantom 350, M-Cubed T-balancer. Let's put it this way, I've got my window open, and a 1 am, it's louder outside than my workstation. My HTPC, even with a bad fan, is drowned out by my projector. |
I have three MVP's that I watch my recorded shows on at various locations throughout my home. They all use regular CAT5 cable. One of the locations I use a very old tv that only has the 2-13 channel available (talkin early 80's here), so I use the MVP to stream live TV so I have the choice to watch my recorded shows or watch the actual live feed from the cable. If you go with SageTV, you might consider getting the MCE500, it has two tuners in it and frequently I am recording two shows at the same time. The nice part is I can buy another and have 4 channels record simutaineously if I want....try that with TIVO!
The MVP is very small and gives as good a picture as your TV will deliever. Hopefully in the future, SageTV will support HDTV. You may have to live in limbo for awhile until that feature gets added to SageTV. Like many of the guys who have responded also, we started off watching recordings off the computer, have purchased the client licience so we could watch stuff on our laptops, they gone a purchased the MVP's so we could really have TIVO-like experiences where and when we want AND on whatever piece of equipment we wanted. Can't do that with TIVO. Tivo is a neat piece of equipment, but if it breaks, get hit by power surges...whatever, it's done. New box. With SageTV, my computer dies, I get a new component, my software is ALWAYS being updated and upgraded by the company (for the better too), and honestly, if the box dies, who cares. I can slam SageTV on another computer and away we go!!! Oh, did I mention anything about storage limits? As long as you have a place to plug in a hard drive, you go more storage space.....try that TIVO!! Good luck and I don't think you will be dissappointed with SageTV, even if it can't do the HDTV thing yet. The features and ease of use are just too good. Bob E.
SageTV ver 5.0.2 Sage Server - Intel D945GTPLR mobo, P4 2.26, 1GB Ram, 80GB HD for WinXP Pro, 750GB for storage, Sony DRU-810 DVD Recorder, (2) Hauppauge MCE-500, (5) Hauppauge MVPs |
Pardon my ignorance, but what is a "MVP"?
Brent |
Hauppauge MediaMVP
Sorry to jump on this thread late and hopefully the original poster will see this. Regarding Tivo, what did it for me to make the switch to Sage was the SLOW transfer rates from one Tivo to another at USB one speeds. I never dreamed of all the other benefits.
Regarding computer workstations, I wanted a full computer and not an MVP. I also did not want to put the computer in the closet because I may want to play a DVD or something. So, I got the AOpen (like a shuttle) from NewEgg and I'm very very happy with them. They measure 12" x 7" x 7" and easily may be put on top of the entertainment center (the very top) or on a shelf. They are VERY quiet. They are about $300 (at least the kind I got but there are others) for barebones and you'll still need a processor, hard drive, etc. I like the fact they come with an svideo out as well as vga. Mike |
Thanks. I did not know that MVPs do not play back the HDTV signals (until someone pointed that out on this list). So, I guess I will need as small of computer as possible for my living room, where the only HDTV will be. I assume then I can use placeshifter to get the HDTV recording from my main computer to my little server computer near my TV. The one you mentioned AOpen-- is that $300 ready to go, or do you have to add the processor, harddrive etc for additional money?
Thanks, Brent Quote:
Thanks. I learned something again!
Brent Quote:
