Request: Auto Aspect Ratio Switcher
Hey,
I was looking for a way to have Sage automatically toggle between different preset of aspect ratios (i.e fill, source) which I can select for each channel. I found the import in the "list" forum that such a thing existed for a previous version of Sage, not not to say the link doesn't work. I would really appreciate someone making such a tool where the plugin basically stores which aspect ratio (the user sets it) to use for each channel. Basically there can be a "default" preset that I choose, which works for all channels except some exceptions which I can identify to use a different preset. I think such a tool would be helpful to alot of people specially those watching both SD and HD TV. Thanks in advance |
An import currently exists and has worked very well in the past. It's Called "Automatic Aspect Ratio Switcher" by nielm...... It works 'almost' great with v6. It currently prevents me from viewing online video content on my client. The audio plays fine but the 'downloading' message stays up and no video. I think a fix is available by disabling the osd - check this forum http://forums.sagetv.com/forums/showthread.php?t=14146
Edit: Setting "Show Debug Window on Setting AR"=Disable under the options menu will fix the online video display problem. Last edited by wado1971; 09-10-2008 at 06:41 AM. Reason: Add - osd fix |
Plugin: Web User Interface for SageTV 2.2-6.6 (V2.25 18 Sep 2009) | nielm | SageTV Customizations | 2644 | 10-24-2016 10:18 AM |
aspect ratio issues | cbarrett | SageTV Media Extender | 3 | 11-29-2006 02:26 PM |
Aspect Ratio | tbonessc | SageTV Beta Test Software | 5 | 11-22-2006 10:15 AM |
Need Another Aspect Ratio Setting | Humanzee | SageTV Beta Test Software | 0 | 03-02-2006 03:15 PM |
Aspect ratio stopped working in V4.1.4 | AMCooper63 | SageTV Beta Test Software | 3 | 01-31-2006 06:57 AM |
