SageTV and Hauppauge 2250
Hi,
Im new to this so pardon this if this is just a silly mistake. It seems the setup wizard only detects I have 2 analog tuners and never asks me to select the source info for the digital tuners. Am I missing something? SageTV 6.4.8.184 Windows XPSP3 Thanks for any help, if more info is needed let me know. |
Select the Analog tuner. The next question will ask you if you will use it to tune Analog, Digital or QAM. It's an all in one tuner.
Server: SageTV 9, Win10/32, Intel DP55KG Mb, Intel QC i5 2.66GHz , 4GB 1333MHz DDR3 SDRAM, 2 Hauppauge 2255s for 4 OTA ATSC tuners, HDHRPrime w Comcast, 3 STP-HD300s 20101007-0 firmware, nVidia Shield. Java v7u55. Plugins:SD EPG, OpenDCT |
That fixed it, thanks again!
Does the Hauppauge 2250 require you to rename and remap channels like I see people have to do with the Silicondust HD HomeRun? Thanks Scat |
My local channels came up perfectly in the Miami-Ft Lauderdale, FL digital over air EPG. I only had to deselect the subchannels I never use. The digital OTA tuners are all I use (no s-vid, QAM or SD). All my other stuff comes from DirecTV via HD PVR.
SageTV V4.1.11 Beta Is Available - Better Placeshifting! | Narflex | SageTV Beta Test Software | 81 | 04-04-2006 09:39 PM |
Successful SageTV Install on Via Epia System with Hauppauge 350 | gazer | Hardware Support | 0 | 03-23-2006 01:48 PM |
SageTV 4.1.3 / Hauppauge WinTV-PVR-150 'HOT' AUDIO issue | shawncochran | Hardware Support | 4 | 02-28-2006 09:42 AM |
My SageTV Experience and Review | mayamaniac | SageTV Software | 21 | 01-07-2005 03:45 PM |
