Two Extenders ... One has the Hiccups (SPIDF Audio Skips )
I have two media extenders. The SPIDF audio out is not working correctly for one of them. The Audio Skips during playback of music and video. It has always skipped when playing Music Files. Since I rarely listen to music I just figured it was a network issue and decided not to try to fix it since the video was playing fine. But recently it started skipping during playing of videos. I just couldn't take that. It seems to correct itself after about an hour. The first hour the audio will skip and after about an hour of playing it will stop skipping and play fine.
After coming to the conclusion that it was not a network issue, I decided to switch the extender with the extender that was in my bedroom. Both have the latest firmware. Both also have SPIDF audio selected as the output. Basically everything is the same. When I switched them out everything played fine. The same files I was trying to play before played perfectly, audio and video. I have even tried 3 different audio receivers. One extender plays fine with all 3 the other one skips. The extender that skips over the SPIDF plays fine via analog so I have actually moved that box to my bedroom which does not have a receiver. Both are playing fine now. However, I'd like to fix it cause you never know when i'll need to use the SPIDF on that box. I think this is a hardware issue with the box that skips. Does anyone konw of anything else I can check to see if it isn't a hardware issue? My receivers don't have HDMI so I'm unable to try out HDMI. |
I have / had this same issue. I just switched to using analog b/c there didn't seem to be much (any?) audio quality differences.
Does a MVP pass surround sound through SPDIF (if it's encoded in the avi file)? Thanks. Todd |
HD PVR No Audio | jbert | Hardware Support | 11 | 07-28-2012 10:26 AM |
Dropped favorite recording -- with debug logs | Surtr | SageTV Software | 4 | 02-19-2008 10:48 AM |
List of issues Sage 6.3.6 with HD extender | Spriter | SageTV Beta Test Software | 5 | 01-24-2008 09:31 AM |
Audio stutter in recorded HD material playback | Bryann | SageTV Software | 8 | 09-12-2006 04:05 PM |
Audio volume levels | KarylFStein | Hardware Support | 0 | 05-21-2006 10:29 PM |
