Old 04-28-2011, 06:18 AM
DaveS DaveS is offline
HD300 vs HD200 scrolling menus
I just got my first HD300 to use in addition to two HD200's on two other TV's, and I noticed a difference in how they behave.
On menus containing lists of recordings or recording schedules, when you scroll down to the last entry, the HD200 stops and you have to manually scroll back up to the top of the list. The HD300 continues to scroll through the bottom of the lists and starts over at the top in a continuous loop. Since I've been using the HD200's for a while, I'm used to them, and I find the HD300 scrolling annoying.
Is there any way to change the HD300's scrolling behavior so that it is the same as the HD200?
Dave S
Windows 10, Sagetv 9.2.1 64b, OpendDCT 0.5.29, 8gb ram, HDHR Prime, 3 HD300
Old 04-28-2011, 06:58 AM
somewhere in detailed setup is an option to disable wrap around scrolling... that's what you need. Each instance of the client maintains its own properties/settings file, that's why they (can) behave differently
Check out TVExplorer
Old 04-28-2011, 08:29 AM
Thanks for the info, Razrsharpe. I saw that option but didn't realize it was for those menus. I'll give it a try.
Thanks again!
Dave S
hd300 media extender, menu loop, menus
SageTV 7 (or HD300): Blu-ray menus/audio not working null_pointer_us SageTV Software 13 01-09-2011 08:24 AM
Sage 7 Server & HD200 - Scrolling Features? Savage1701 SageTV Media Extender 0 11-25-2010 04:12 PM
Copy SageMC menus to new HD200 ScubaMedic SageMC Custom Interface 3 09-17-2009 11:23 PM
HD200 import custom menus PLUCKYHD SageMC Custom Interface 7 02-16-2009 01:19 PM
