Old 01-14-2007, 04:18 PM
Dead MVP?
Okay, so this morning I went to watch tv in the bedroom thru one of my MVP's, and the bootup screen showed all 5 load bars but nothing happening. Pulled the plug, restarted, it didn't actually go thru the "loading" it just showed the main screen with all 5 bars and sat there. I started looking at the cables and realised one of my dogs must have chewed the ethernet cable, and now there are no lights off the ethernet port. I took the unit apart and could not find any fried capacitors/resistors/etc. It is almost like the bios/firmware is screwed up. Anyone know of a way to "flash the bios" of the MVP or is this some kind of "screen of death"?
Old 01-15-2007, 04:42 PM
rickgillyon's Avatar
You've tried rebooting your router and blowing away the Clients folder?
