Old 03-12-2007, 12:29 PM
gwgunter's Avatar
gwgunter gwgunter is offline
Weird Select or Click Issue
Anyone having an issue where you can not click into a sub-menu without first moving off of the selection and then moving back to the original location for it to select. This appears to be happening only on my MVP's. I tried deleting the clients folder and reinstalling the release candidate but didn't work.
Old 03-17-2007, 03:59 PM
criccio criccio is offline
I've seen this, but only when using my Home Theater Master MX-500 remote. The remote that comes with the MVP doesn't have the issue. Scanning the forums there's some topics on potential fixes, but i haven't tried any yet, i've just used the MVP remote for now
Old 03-18-2007, 08:23 AM
gwgunter's Avatar
The mx-500 was the problem. The haup remotes work fine.
Old 05-23-2008, 03:31 PM
InsertHere's Avatar
InsertHere InsertHere is offline
I've searched all over the place without any luck. Has anyone found a solution to this?
Old 05-23-2008, 11:46 PM
snapdaddy snapdaddy is offline
Same problem with Tivo peanut
Originally Posted by criccio View Post
I've seen this, but only when using my Home Theater Master MX-500 remote. The remote that comes with the MVP doesn't have the issue. Scanning the forums there's some topics on potential fixes, but i haven't tried any yet, I've just used the MVP remote for now
I'm using my Tivo peanut (wife loves them) and am having the same problem. I assigned all the commands to the HD extender, and all seems to be working, except this "move to select" problem.
Old 06-25-2008, 08:55 PM
Wouldn't you know it...
10 minutes after I submitted a bug report to Sage about this issue, I found a thread from last year mentioning the "rc5_disable" property.
I added the line:
rc5_disable=TRUE
to my extender's properties file (in the clients subdirectory) and the problem disappeared.
I swear, I looked for the answer (several times!) before bothering the Sage guys!!
Old 06-26-2008, 08:39 AM
InsertHere's Avatar
That worked great! Thanks.
After making the change a bunch of my IR commands were unlinked, so had to be reprogrammed, but that's worth it to have the other issue gone.
Now if I could just figure out how to make the remote stop sending the same command twice half the time!
Help with New Install - weird behavior glmason SageTV Software 7 05-23-2007 05:41 AM
Netflix on Sage matrix35 General Discussion 24 03-07-2007 02:32 PM
Issue with 5 minutes of audio at beginning of recording gone, video is fine? GoldenTiger SageTV Software 3 02-12-2007 05:35 PM
Still getting weird Slo-Mo issue with V5 Jesse SageTV Software 9 06-23-2006 07:48 PM
Issue using new MediaMVP box and 4.1.11 FJC SageTV Beta Test Software 7 04-10-2006 10:51 AM
