HD-PVR 1.0.3.53 Beta AC-3 5.1 Audio Drivers are out
see this page http://www.shspvr.com/smf/index.php?topic=11718.0
Rack Server: WHS Intel Quad Core, 3GB RAM, 3 HD PVRs, 4.5TB Storage and growing. Rack Server: Dual Core 2.0Ghz, 320GB - Home Automation/Security/SQL Server Client 1: HD Extender on 42" Samsung 1080P LCD and 92" Epson 1080p Projector. Gaming Rig:Q6600 Quad O/C to 2.8ghz, 4GB DDR2 1066 RAM, Geforce 8600GTS Misc: Onkyo TX-SR705 Receiver, Netgear Pro Safe 16port Gig Switch, Cat6 cabling, Linksys WRT54G running tomato firmware |
I'll test tonight if I can get out of this office - Congress didn't help my situation much today.....
Biggest question to answer: Does it fix the audio sync problem on 1080i recordings on the extender?
Well find out I guess. Glad I ordered that S/PDIF cable from monoprice
Seems to work!
I have installed the new drivers however I'm not getting any video or audio when I select Component + SPIDF for the HDPVR. When I switch it back to Component I get audio and video but it is still 2.0. I'm not sure if I did something wrong of if Sage needs to be updated to take advantage of the new drivers.
I get Code 39 in my device manager on both of mine with this driver in Vista x64
Brent has that part wrong by default it 2.0 audio if there is no 5.1 but if there is 5.1 it will recod 5.1 audio you don't need change any thing and yes it in sagetv as 5.1.
Some of this depend on how you setup your settop box For Example on Dishnetwork Dolby Digital/PCM Dolby Digital Only PCM Only You want to use Dolby Digital/PCM option Last edited by SHS; 09-29-2008 at 04:51 PM. |
ToxMox have check and made sure the drivers really got install check see in the device manager for 1.0.3.53
One thing to try is power down the PC and unplug HDPVR and repower everthing back |
Is the FTP site down? I can't get in to d/l these.
S |
no it not down
Thanks, I got them. Just had to be persistant.
Do these drivers fix anything other than 5.1 audio? Such as the known issue w/ 720p recording or the "No Signal" errors in Sage when the device stops responding? Fixing the "No Signal" error is 10 times more important to me than DD 5.1. S |
Now, if I could just get them to stop locking up every so often... but I have no idea if this newer driver could have any effect on that. - Andy
I never had that problem with 720p recording so best thing to do is try them out and you fimd any problem make a post on shspvr forum so the software dev can look at that.. |
im short on optical audio cables, so i will upgrade the drivers saturday and report in. i am running 3 hd pvrs, so if i have issues i will know pretty quickly. lol
oops. corrected this in my post
5.1 audio is not been recording with SageTV Last edited by SHS; 09-29-2008 at 06:48 PM. |
So far so good. I was getting 384k Dolby Digital 2.0 out of my recordings which would seem to indicate it's recording the bitstream.
HD PVR No Audio | jbert | Hardware Support | 11 | 07-28-2012 10:26 AM |
Watch live TV with SageTV and HD PVR? | Tiger62 | Hardware Support | 2 | 09-26-2008 06:39 PM |
Another HD question, audio this time | opy01 | Hardware Support | 2 | 09-25-2008 07:20 AM |
Which Decoder (Video & Audio) do you use with HD PVR? | chasmetz | SageTV Beta Test Software | 6 | 08-08-2008 12:04 PM |
Connecting HD PVR to computer | johnwmreed | Hardware Support | 9 | 08-01-2008 08:40 AM |
