HD200 "Source" Aspect Ratio
There still is a problem with playing back DVDs that are 4:3 formatted on the HD200 extender.
I have my HD200 set to default to "Source" but every time I playback a 4:3 DVD, it stretches it horizontally until I cycle through all the aspect ratios to end back up at Source again. the HD100 does not have this issue. Stacy |
What firmware are you running?
Sorry..... currently I am on the latest beta from 4/28. However it's been this way on every FW release since the HD200 came out.
Stacy |
Well, I just tried it out and I'm using Sage v6.5.9 with the latest release version of firmware (20081230 0, I believe). In my case, I noticed my 4:3 DVDs start horizontally stretched and cycling through the AR modes doesn't fix it. Oddly enough, I noticed cycling through the AR modes for widescreen DVDs screws it up.
I don't have my HD100 (I sent it in for repair), but I'm pretty sure the 4:3 DVDs worked fine with the current release firmware. But, I do recall having various AR related problems earlier on. I think most of them were fixed in various firmware releases. However, I know I had some DVD menus that never worked correctly on the HD100. After going back and forth with SageTV support many times, it seemed like an isolated issue, possibility caused by how the DVD was created. But, we never really found out anything for sure. As I said, I'm running the latest HD200 release firmware. I'll try the newest beta from the 29th. I was running the previous beta very briefly, but all 4:3 material played back stretched out in that material, including TV recordings. Hopefully yesterday's beta doesn't have that issue. |
same here on 4:3 DVDs............video files do aspect ratio correctly but not 4:3 dvds
dvd menu comes up stretched............if i cycle to source aspect ratio, it goes back to stretched when movie/show starts, and i have to cycle through yet again works great on video files, not apparently persistent for DVDs though also running latest beta |
Maybe you guys can help me out. When I run the beta firmware (both the previous and the April 29 firmware) I always get horizontally stretched 4:3 playback, and vertically compressed 16:9 playback. So, basically, I think the HD200 thinks I have a 4:3 TV when I'm playing video back. But, the AR display mode is correctly set to 16:9, and the Sage menus look OK (that is, they're not stretched), and the properties file for the extender indicates its using the 1.77778 AR display mode.
Now, I am running SageMC. So, I'm not sure if that's causing problems here. Also, I'm connected via component cables. Any ideas? In the meantime I'm going back to the release firmware. Luckily firmware updates are pretty quick on the Hd200. |
Is anyone running the April 29th firmware with SageMC without running into AR problems on recorded TV files?
Well, this isn't a SageMC issue. I tried switching back to the stock UI and I still have issues where the HD200 plays video back like I have 4:3 TV, despite the fact that it is correctly configured for a 16:9 TV.
i created a bug report so it is officially reported now
I did too. But, it sounds like I'm the only one experiencing issues with 4:3 formatted recorded TV files.
yes, we're different.........i'm running hd200 as a standalone media player
The problem is just dvds for me as well. It's the same issue in both standalone mode and in extender mode with default interface. Recordings are fine.
please file a bug report and help them track this down
OK, so I resolved my initial problem with playing back TV recordings. I'm not sure why it fixed it, but deleting the properties file associated with my extender fixed that AR issue.
But, I'm definitely noticing the aspect ratio on 4:3 DVDs even in today's 20090505-0 firmware. I actually think this is the same, or at least a very similar, issue that I ran into with the HD100 a bit more than a year ago. I think Sage sort of had (what sounded to me) like a goofy fix. I think they made it so you couldn't change the aspect ratio mode when you were in DVD menus. That made it so you couldn't cycle through the AR settings in DVD menus, getting back to source with black bars on the side. That was bad for DVD menus because then the menu highlighting didn't match up with the menu items. I'm not sure if that somehow fixed the AR issue in video playback or not. |
It looks like this issue might be fixed in Sage 6.5.15. I think Sage determined that 4:3 menus were suppose to start out zoomed/stretched. So, I think that the menus will still take up the whole screen, but the 4:3 video should play back unstretched.
I haven't tried it yet. I upgraded to the May 5th firmware, and I'm trying to decide if I'm going to downgrade the firmware to the release version, or upgrade SageTV server to the beta (6.5.15) to try to resolve the stuttering issue. I've been avoiding beta software for a while because I didn't have good luck with them in the early SageTV v6 days. It is much easier to downgrade HD200 firmware than downgrade SageTV if I have problems with 6.5.15. |
The Tudors season 2 discs (16x9) are still not behaving correctly with "source" aspect ratio. It is still adding extra black bars to the top and the bottom as if it were trying to letterbox it for a 4x3 TV (so you get a vertically squished image on a 16x9 display). The menu audio on those discs is also coming out as garbled noise (using optical out, I don't have analog outputs connected) although the episode audio is fine. Again no problems with either aspect ratio or menu audio in the SageTV software on the computer. |
I figured out last night that the only reason deleting the properties file did anything for me was because I failed to turn back on native resolution switching. When I turn that back on my weird aspect ratio problems come back. |
Aspect Ratio: All freeze but "Source" | m2cupcar | SageTV Software | 1 | 06-23-2008 12:03 PM |
Made a custom Aspect Ratio to "add overscan" on the HD100 | Slipshod | SageTV Media Extender | 8 | 03-27-2008 07:04 PM |
Why doesn't the "Source" aspect ratio work? | Bozrdang | SageTV Software | 11 | 02-13-2005 07:04 PM |
Aspect Ratio "Source" Doesn't work | Air | SageTV Software | 5 | 09-14-2004 10:40 PM |
Problems with "Use Source" Aspect Ratio Mode | stanger89 | SageTV Software | 5 | 10-07-2003 06:40 PM |
