HD200 Aspect Ratio Mode
Hi Guys,
When using the HD200 as a Sage Extender does anyone know to permanently change "Aspect Ration Mode" to FILL ? I need to change it everytime I turn if on or a new program starts, seems to always want to default to "SOURCE" Thanks |
When playing a video, hit the "options" button. From there, go to aspect ratio control, select "fill", go into it's settings and set as default.
-festus |
Try this. Set the aspect ratio to "fill". Then power down the HD200. After you power it up your setting should "stick". This has been an issue for a long time.
See this... http://forums.sagetv.com/forums/showthread.php?t=37561
2.3 GHz AMD Phenom 9600 Quad Core, 2GB DDR2 RAM, Asus M4N78 Pro MB, XP Pro, PVR150, PVR1600, HDHR, HDPVR x 2, USB-UIRT, 160GB OS HD, 500GB SATA Recording HD, 500GB USB Media HD, HD100 x 2, HD200 x 2 |
That didn't work for me, but what I did was went into the properties file for each of my HD200(s) and changed the... i think it was
"advanced_default_aspect_ratio=" to "advanced_default_aspect_ratio=Fill" It was near the top of the properties file. if you search for aspect it is the second instance of it in the file... at least it was for me. ~Mike |
If this works, i will buy you a beer. I have always had to hit the aspect ration button each time i watch my shows... I wish sage will give users that option to default it to fill. The aspect ration is the most annoying thing to me in sage.
Server (Headless): AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Mother Board: ASRock A780GMH/128M Memory: 4gigs OS: Ubuntu Jaunty 64bit Server - Kernel 2.6.35 Capture Devices: HD Homerun (QAM), Hauppauge WinTV-PVR-500 MCE, HVR1800 & HVR 980 (collecting dust) Clients: 2 x HD200 (beta firmware-latest), 2 Laptops & PC's running Client 7.0.16RC NAS: Software Raid + LVM Storage: 2 x 500gigs @ Raid1, 2 x 1TB @ Raid1, 2 x 1.5TB @ Raid1 |
Using 6.6..but I have not tried to set the aspect ratio for a long time, therefore I was not aware the issue had been addressed.
2.3 GHz AMD Phenom 9600 Quad Core, 2GB DDR2 RAM, Asus M4N78 Pro MB, XP Pro, PVR150, PVR1600, HDHR, HDPVR x 2, USB-UIRT, 160GB OS HD, 500GB SATA Recording HD, 500GB USB Media HD, HD100 x 2, HD200 x 2 Last edited by dadof4; 08-04-2009 at 06:18 PM. |
Aspect Ratio mode: not keeping | rdefino | SageTV Software | 0 | 11-20-2008 07:45 AM |
Aspect Ratio Mode | jphipps | SageMC Custom Interface | 0 | 10-20-2008 06:52 PM |
Problem with aspect ratio mode | delgrego | SageTV Software | 10 | 03-23-2007 02:35 PM |
Help with Aspect Ratio Mode? | corykim | SageTV Software | 4 | 08-25-2003 09:48 AM |
Aspect Ratio Mode changes... what do they change?!? | jimbobuk | SageTV Software | 2 | 05-12-2003 02:04 PM |
