Old 06-16-2010, 02:30 PM
JREkiwi Close Media file
Is there any chance of getting this ported over to SageTV7? Upon completion of watching a show Sage7 keeps the file open.
Old 06-16-2010, 03:29 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I included it in the Multi Function Stop plugin. Seemed a logical place for it to go, but I could do it as a separate plugin if you want.
John
Old 06-16-2010, 03:37 PM
Thats ok I have that installed. I will look for the settings.
Ok its working Thanks
Old 11-10-2012, 03:39 PM
cyberlewis cyberlewis is offline
Request for 'Close Media File' as a Separate Plugin
Hi John,
I discovered this thread today from a Google search. I used to use your Multi Function Stop plugin for SageTV 7 solely for the close media file on finish functionality (yeah, I don't understand why this isn't the default behavior either), but finally decided that I didn't want to hit the stop button twice anymore, so I removed it. I didn't realize that you had once offered to break the Close Media File functionality out into a standalone plugin for SageTV 7. I don't know if you would still be open to the effort required for such a thing, but I would certainly use it.
Thanks for the consideration,
Brian
Old 11-10-2012, 05:58 PM
JREkiwi's Avatar
Brian, I went the much easier route. I've added an option to disable the Multi Function Stop
Setup / Detailed Setup / Customize / Multi-Function Stop.
An update is in the plugin repository.
John
Old 11-10-2012, 08:40 PM
This is so great!
Thank you John!
Old 11-16-2012, 01:36 AM
silkshadow's Avatar
silkshadow silkshadow is offline
Awesome, thanks from me as well!
close video at end of file dvd_maniac SageTV Software 6 02-13-2009 12:00 AM
Close Sage from a batch file? TBacker SageTV Software 1 06-10-2007 12:04 PM
Videos dont close at the end of a file Speedy64i SageTV Beta Test Software 0 08-14-2005 12:46 PM
Close file deleted my recording jcclow SageTV Software 12 08-19-2004 07:46 PM
Question: what's the close file command for?? LostInSpace SageTV Beta Test Software 1 04-24-2004 06:21 AM
