HD200 randomly turns off navigating menus
For the last couple of weeks I've had some trouble with my extender just shutting off while I navigate menus. It isn't happening at the same point every time but it does seem to happen more often in the imported videos menu. It did this to me 3 times last night so I figured I should post something. Quite often the GUI will just freeze for a few seconds, and then the extender will shut off. I'll turn it back on and be able to reconnect right away, nothing seems to happen to the server.
I'm not sure what to even looked at to start troubleshooting this problem. I haven't yet installed the last two RC's of sagetv, but I believe everything else is up-to-date. I'll check tonight and get specific versions of things. In the meantime I will continue to search the forums to see if anyone else has had this issue. I couldn't find anything earlier.
SageTV: Athlon 64 X2 4200+ | 4 GB | 1 Tuner | DirecTV via HD-PVR | Windows Home Server 2011 Clients: PlaceShifter | (3) STP-HD200 Primary TV: Samsung 61" DLP 1080p Bedrooms: Toshiba 32" LCD 1080p Customizations: Pheonix | Web Server www.jiff.net |
I had a similar issue. It wasn't so much with menu navigating. But it would freeze/turn off. Tracked it down to a network card issue on the Sage server. DHCP was momentarilly shutting down the connection while denying the IP renew. Look at your NIC card and any logs on the server.
I've seen similar behavior. My HD200 turns off when I am in the recordings menu and I hold down the up button to scroll to the top of the list of recordings. Occasionally when I hit the top of the list the extender powers off. I passed it off to an IR glitch, but maybe it is actually a bug. I haven't filed a bug report since I haven't tested with hidden extras and add-ins disabled.
SageTV v9.1.10.479 on Ubuntu (testing v9.1.10.479 on Debian and Win10) |
Mine just started to do this with the 20100909 version of the firmware installed. Anyone know if there is a way to reflash with the same firmware? I have tried resetting with the restart with delete pressed but this has not fixed the issue. I have had issues with the HD200 not starting up or having some kind of error about once a month and resetting did the trick. I am assuming something is corrupted maybe so I would like to reflash and see if that fixes this. Right now, I can navigate for all of 15 seconds before it freezes and shuts down. Needless to say WAF is negative right now.
SageTV 7.0.0.23, P5Q-EM Motherboard, 2.5Ghz Quad Core, Windows 7 x64, HVR-2250, 8GB RAM, 1TB HD, 2 HD-200 Extenders |
Having the same issue here with 2 HD200's. Once while navigating the menu's and at least 4 or 5 times while listening to music. The only way to get it back is to cycle power. I have noticed lately that video and music will unexpectedly pause for a few seconds and then resume lately as well. No server or network changes have been made recently. Using firmware 20100909 0.
I pressed the power button on the remote, the active light turns red for about 1 second and then turns off. I am becoming increasingly frustrated with my SageTV products. I've a;sp had problems with my HD300 (also randomly turns off, shocks and turns off when touched), I have (what I believe) are bugs in SageTV which while annoying aren't significant enough to spend the hours necessary support required for me to troubleshoot. Unfortunately, there really aren't many other alternatives. Last edited by davidjames; 03-11-2011 at 04:11 PM. |
I get the music playing shutdown issue randomly. I have 2 HD200s but I haven't swapped to check the other. Sometimes it will play for hours, sometimes not very long at all. I don't know if it's related, but every once in a while while playing music something strange happens to the video output (at 1080/60p) and my Samsung DLP loses the image and reports "Mode Not Supported." It usually comes back when I push some buttons, but sometimes I have to use the "video out" button and cycle through the different modes to get it to come back. I don't think it's related to the visualizations or screen saver. I switched to 1080i output and it doesn't seem to trigger this issue anymore. I haven't had it shutdown since doing so but I also haven't left music playing for very long to find out for sure.
I also have this problem. My HD200 will freeze and I have to unplug and replug to reconnect. I have two HD200s, and have had both units do this similtaneously. I have completely rebuilt my server (all new hardward--NIC included), replaced my router, and updated software/firmware. The problem went away for awhile after the rebuild, but it is now back and happening with increased frequency. Frustrating.
since there hasn't been a firmware update since September, 2010, and there have been several releases of Sage 7 since then, is it time for a firmware upgrade for the HD200?
I get garbled characters on the "connecting to server" screen, and a few shut-downs, freezes. |
HD200 turns itself off | Grant.Edwards | SageTV HD Theater - Media Player | 5 | 05-21-2010 05:41 AM |
HD200 powers off randomly | coolpup32 | SageTV HD Theater - Media Player | 15 | 09-18-2009 10:53 AM |
HD200 turns off after screen saver | freedml | SageTV Media Extender | 0 | 03-03-2009 07:28 AM |
Audio distortion on music playback while navigating menus | dougsing | SageTV Software | 0 | 12-01-2008 02:20 PM |
HD100 randomly turns itself off | Ryand833 | SageTV Media Extender | 7 | 06-03-2008 05:07 AM |
