Colossus problems solved? (knock on the wood)
I might have solved the infamous Colossus problems. In the last two days I have not had any freezes, "fast forwards" or out-of-sync sound.
I disabled the "Cool and Quiet" functionality in BIOS, forcing my AMD-FX 8core 3.6GHz CPU to run at its max. clock rate all the time. No scaling down. Since then, so far so good. Let's see what happens in the nearest future. Cheers Frank |
Hmm I have look in to that one as well
Very Interesting so far it been a week and no reboot
![]() Last edited by SHS; 06-03-2013 at 09:15 AM. |
That doesn't make since. While USB is CPU driven, the slowest clock speed of modern computers can easily handle a USB 2.0 device at full speed.
It also throws out any kind of software or memory leak issue???? (which I thought was the latest theory) If it keeps working, someone PLEASE report this to Hauppauge, and see if they can figure out why this would fix things!!!!! (and maybe a driver fix????) BTW, did you also get the latest "Windows" driver update at the same time??? (Not at home, can't check version/patch, just remember getting one by Windows update)
Server #1= AMD A10-5800, 8G RAM, F2A85-M PRO, 12TB, HDHomerun Prime, HDHR, Colossus (Playback - HD-200) Server #2= AMD X2 3800+, 2G RAM, M2NPV-VM, 2TB, 3x HDHR OTA (Playback - HD-200) |
MattHelm the Colossus is 1x PCIe not USB
Oops, too early in the morning for me to post!!!
![]() Still, the same applies to PCIe, except being CPU driven, only more so. Again, the CPU clock should never effect the PCIe bus.
Maybe this will help
Hmmm, wonder if this would also apply to the equivalent Intel technology...
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.9.2, sagetvopen-sagetv-server-opendct-java11 Docker Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
Yes it has to do with SpeedStep or EIST that Intel technology that equivalent to AMD Cool and Quiet functionality in BIOS
What the ............
Going to check to see if my board have that feature .... Bill
HTPC System GIGABYTE GA-MA69GM-S2H AM2 AMD 690G HDMI // AMD Athlon 64 X2 6000+ Windsor 3.0GHz // G.SKILL 6GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR // Hauppauge Colossus HD-PVR // Hauppauge Colossus HD-PVR // Seagate ST3750640AS 750GB SATA-300 16MB // DVD R/W - SAMSUNG Black Media Extenders HD300 HTPC Software Windows 7 Professional 64bits // SageTV 7.1.x // Java 1.7.x |
My board had "Cool and Quiet" set to Auto so I disabled it.
I also set my CPU fan to run at max setting since the server is in the basement and we cannot hear it. Gonna disable the nightly reboot for a couple of night and see what happens now. Bill
that's great news.. I do hope it would work in Intel boards as well (I'm runing Intel) and that sounds like an easy fix.
I do remember Colossus had a longer tune time though. HD-PVR seems to tune fairly quickly by comparison. |
Give it a week TechBill let me know how it goes.
Yes I will talk to hauppauge about this, matter fact I have talk them about USB 3.0 Problem with HD-PVR 2 which seem be have problem starting a record some time it up to 3 mins before it starts. Yes please try it sacrament055 and let me know how it goes. The only thing I can think of is that sagetv doesn't support the new type power management or colossus is at fault here that I really don't know. |
Maybe that's why I never really have issues with the colossus? I've always disabled those features.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
So far no problem but we haven't been using TV much lately. Bill
I had to restart SageTV today to fix my EPG but I had zero problem since I stop doing nightly reboots and not have rebooted server yet.
The server did not have a monitor and keyboard hook to it for years because I always use the remote desktop to fix or make changes on it. So it was weird hooking up a keyboard and a monitor after all those years to the server to access the bios to change the settings. There were dust and spider webs in the usb slot =P Bill
4 days now of no rebooting ......
Anyone else testing this too? Result? Bill
So far so good I hoping some one with intel post here to
I don't ever reboot on my intel system. I've never had any of the power options enabled so I can't comment on whether that is everyone's issue. I do have to restart the sage service about once a week or video gets choppy. That's it though.
you people are making me think about trying out my colossus again.
Trying to use my old wiz.bin from version 6 [SOLVED] | bbig119 | SageTV Beta Test Software | 2 | 09-07-2010 09:12 AM |
WIZ.BIN is insane; solved | src666 | SageTV Software | 15 | 03-06-2010 06:19 PM |
Old Direct TV box controller problems solved? | Profcrab | Hardware Support | 4 | 01-05-2007 09:54 AM |
PVR 350 Problems solved? | Bathman | Hardware Support | 2 | 11-17-2004 03:04 PM |
2.1 Please knock my socks off.. | edbmdave | General Discussion | 7 | 10-12-2004 05:19 PM |
