Old 04-05-2017, 04:14 PM
Vitalogy Vitalogy is offline
New set-top box, no signal in SagetV
*solved*
**Update
Opss, stupid mistake. I inverted some component cables...
Now I have video signal but... no sound. Maybe I need to adjust some option in the Explorer?
I will come back if I find the solution.
**Update 2
Still no sound, and I have no idea what to do next.
Note: Old recordings (before the new set-top box) have sounds. So that seem a problem with the recording, not with the playback.
**Update 3
SOLVED !
I restored a backup I did before the changes to remove the updated Hauppauge driver and now everything work fine.
Hi, long time user here.
I love SageTV but I hate the fact that I get lots of problems when I try to change anything... :-(
My cable provider forced me to upgrade my set-top box, and guess what? SageTv dosn't work anymore.
SageTV v7, Windows 10 32bits
Cable provider: Vidéotron
new set-top box: Cisco Explorer 8642HD
card recording: Hauppauge HD PVR 2
tuning: USB-UIRT
I use component cables to connect the Explorer to the Hauppauge, then USB cable to connect Hauppauge to the PC
The problem:
The Hauppauge card seem not working, the light is greenish or yellowish (I hope I tell the correct colors... I'm colorblind ;-) ). On TV all I see is a black screen with the words "No Signal". Note: the channel tuning work. I actually see the change of channel on the Explorer.
What I tried to resolve the problem:
  • reboot everything (PC, Hauppauge device, Explorer device)
  • Update the Hauppauge driver
  • in SageTV, remove the video source, then add a new source
So what's wrong? Any ideas...?
qam no signal - everything will work but sagetv skavinger Hardware Support 14 03-14-2010 10:15 PM
How Do I Get HD signal to SageTV SDeGonge Hardware Support 7 02-02-2010 08:12 PM
No Signal in SageTV clarenceb5 Hardware Support 3 01-23-2009 03:24 PM
SageTV looses signal DVB-C mandrup80 Hardware Support 6 06-08-2008 10:56 AM
How to record non TV signal with SageTV? JParedis SageTV Software 4 06-13-2007 04:29 AM
