Old 06-25-2017, 03:33 AM
Vitalogy Vitalogy is offline
Upgraded to v9 -> Hauppauge remote problems
Hi,
Like many others I just upgraded to SageTV v9 to use the Schedule Direct EPG.
It was easier than expected (thanks to the devs who made the windows installer) however I now have problem with my Hauppauge remote. Not every buttons are working.
By example,
the Play, Pause, Fast Forward, Channel, Volume and few others are working.
the Up/Down/Left/Right arrows, TV, Video, Guide and some more are NOt working.
The weird thing is that the problems started after I have rebooted my computer. Or maybe I was lucky and only used working buttons before the reboot. I'm not sure.
My remote is the 45 buttons Hauppauge remote.
I checked in the settings (commands tab) and the correct remote is choosen.
I know that the remote work fine because I tested it with a debug.txt file and all buttons are working in that file.
Any solution for me?
Thanks in advance for your help.
EDIT:
It's OK. After searching in the forum I found something that made me remember that I need a special Irremote.ini file. I restored a backup of this file and everything working fine now.
hauppauge remote problems sg010 Hardware Support 5 05-28-2007 10:53 AM
Hauppauge MCE Remote Problems kaudley Hardware Support 8 02-14-2007 08:25 PM
Hauppauge Remote Problems AWS Hardware Support 1 10-29-2006 10:45 AM
Problems with Hauppauge Remote No-Focus Mod fastoy Hardware Support 6 06-04-2006 09:41 PM
problems with hauppauge remote + sagetv disgust Hardware Support 1 01-26-2005 01:56 AM
