Old 07-23-2007, 05:54 AM
navels navels is offline
Network traffic to/from MVP
I have been using Network Monitor (Microsoft's latest version of netmon) to troubleshoot a problem on my home network. Here is a capture showing traffic between my XP box that runs Sage server (192.168.1.2) and my wired MVP (192.168.1.100):
159 38.000000 192.168.1.2 192.168.1.100 TCP TCP: Flags=...PA..., SrcPort=31099, DstPort=4126, Len=8
160 38.000000 192.168.1.2 192.168.1.100 TCP TCP: Flags=...PA..., SrcPort=31099, DstPort=4126, Len=88
161 38.000000 192.168.1.2 192.168.1.100 TCP TCP: Flags=...PA..., SrcPort=31099, DstPort=4126, Len=8
162 38.000976 192.168.1.100 192.168.1.2 TCP TCP: Flags=....A..., SrcPort=4126, DstPort=31099, Len=0
163 38.000976 192.168.1.100 192.168.1.2 TCP TCP: Flags=....A..., SrcPort=4126, DstPort=31099, Len=0
164 38.000976 192.168.1.100 192.168.1.2 TCP TCP: Flags=....A..., SrcPort=4126, DstPort=31099, Len=0
165 38.083008 192.168.1.100 192.168.1.2 TCP TCP: Flags=...PA..., SrcPort=4126, DstPort=31099, Len=16
166 38.083008 192.168.1.100 192.168.1.2 TCP TCP: Flags=...PA..., SrcPort=4126, DstPort=31099, Len=4
167 38.083008 192.168.1.2 192.168.1.100 TCP TCP: Flags=....A..., SrcPort=31099, DstPort=4126, Len=0
This repeats roughly every two seconds. Is all this chatter really necessary, or does it indicate some kind of misconfiguration? I was not using the server or the MVP when the above was captured (nothing recording, playing, not using the remote, etc.).
Lee
Hauppauge Media MVP problem tktplz SageTV Media Extender 9 03-01-2007 03:31 PM
turning off MVP over network banmj SageTV Media Extender 0 11-08-2006 08:44 AM
SageTV software with Hauppage MVP problems continued dbritton SageTV Media Extender 4 11-07-2006 06:59 AM
MVP Network Question rmbu SageTV Media Extender 5 01-07-2006 12:24 PM
MVP Never Progresses past "Starting Application" MrApollinax SageTV Media Extender 49 01-03-2006 04:25 PM
