Old 04-28-2020, 03:03 PM
jvl711's Avatar
jvl711 jvl711 is offline
Format Detector Plugin for SageTV
Hi,
I have worked with Narflex to add some new features to SageTV.
1. Added forced as a property to subtitle tracks
2. Added 4k resolution to the pretty resolutions
3. Added HEVC (H.265) as a known media format
4. Added the ability to have a custom Format Detector Plugin to SageTV
I have created a JNI Wrapper around FFmpeg for SageTV use https://github.com/jvl711/JavaFFmpegLibrary
I have created a new format detector plugin based on the JNI wrapper library https://github.com/jvl711/MediaFormatParserPlugin
I was hoping to see if I could get help from the community on two items.
1. Beta testers. I need users who are comfortable with the risk of testing this.
2. I could use a developers help with the JNI wrapper library. I would like to make it so the project can compile for both windows and linux. I am a Java/C# developer, so that aspect is a little foreign to me.
Let me know if there is any interest. I still have some work to do before anyone could test.
FYI. I have been using the format detector code on my personal server for a few months. I feel pretty confident on it's stability at this point.
Installation instructions and additional information
https://github.com/jvl711/MediaForma...ster/README.md
If you would like to support my work you can become a supporter here Patreon
Josh
Old 04-28-2020, 05:01 PM
KryptoNyte's Avatar
Holy smokes, a new plugin!!! Awesome.
I'd be happy to beta test, just let me know what I need to do to get it installed on my server and then how I would test something like this. I do have some 4k drone video, and I could probably find some 4k samples to download, but I do not have any other 4k content.
Old 04-28-2020, 08:57 PM
trk2 trk2 is offline
Hey this is great! I would also be happy to test.
Old 04-28-2020, 10:00 PM
I will beta test.
Old 04-29-2020, 08:25 AM
I'm curious if this means forced subtitle tracks in mkv files will now be respected even over extenders?
Old 04-29-2020, 10:39 AM
jvl711's Avatar
Yes. As long as the track is properly marked, and the client has the ability to render it.
The track needs to be marked with the language that you have configured as your audio language, and be marked as forced.
Josh
Old 04-29-2020, 10:52 AM
jvl711's Avatar
I am glad to see there is interest!
Please give me a few days to create some release packages in github for all of the packages. I will also need to make pull all of the items into one package with installation instructions. I will update the top post with that info once I have completed those steps.
Josh
Old 04-29-2020, 02:31 PM
jvl711's Avatar
That went a little quicker than I thought. Please review the install directions and let me know if it makes sense. I am hoping after the initial alpha/beta testing I can attempt to package this into a plugin of some sort.
If you feel comfortable with the directions you can try to install and test. If there are any questions about the instructions please let me know and I will try and clear them up. If you do the full reindex you will see something like the following in your log file for every file.
Wed 4/29 15:31:50.482 [main@65b54208] MediaFormatParserPlugin processing complete: \\egypt\tv\Gotham\Season 04\Gotham - S04E21 - A Dark Knight One Bad Day.mkv
Wed 4/29 15:31:50.498 [main@65b54208] Redetecting format for TV file because it changed:MediaFile[id=943 A[951,950,"Gotham",0@1028.17:05,43,T V] mask=TV host=Development encodedBy= format=MATROSKA 0:43:46 1468 kbps [#0 Video[HEVC 23.976025 fps 1920x1080 16:9 progressive]#1 Audio[AAC 48000 Hz 6 channels  idx=1 eng]#2 Subpic[SRT eng]{MediaType=TV, metadata.tmdb.id=60708, metadata.lastupdated=1583358208346}] \\egypt\tv\Gotham\Season 04\Gotham - S04E22 - A Dark Knight No Man's Land.mkv, Seg0[Sun 10/28 17:05:04.133-Sun 10/28 17:48:50.833]]
Wed 4/29 15:31:50.535 [main@65b54208] Using the format detector plugin
Wed 4/29 15:31:50.536 [main@65b54208] MediaFormatParserPlugin processing: \\egypt\tv\Gotham\Season 04\Gotham - S04E22 - A Dark Knight No Man's Land.mkv
Wed 4/29 15:31:50.537 [main@65b54208] Find stream info called
Wed 4/29 15:31:50.542 [main@65b54208] MediaFormatParserPlugin processing complete: \\egypt\tv\Gotham\Season 04\Gotham - S04E22 - A Dark Knight No Man's Land.mkv
Josh
Old 04-29-2020, 03:57 PM
Josh
All installed appears to be working ... anything else I should look for in the logs ?
looking good ....
MediaFormatParserPlugin processing: \\EDSYNOLOGY\Public\Playon\TVShows\Star Trek_ Voyager\Season 6\Star Trek_ Voyager - s06e10 - Pathfinder.mp4
Old 04-29-2020, 04:48 PM
jvl711's Avatar
looking good ....
I am glad it installed without issues! I assume you also got a line in the log that said "MediaFormatParserPlugin processing complete:" too. Did you do a full reindex? or just test a few files?
I would be interested to know if it is properly identifying 4k content now. Specifically with HEVC (h.265). I would also like to know if it now can detect files with forced subtitles, and it they are automatically selected when you play a media file, when applicable. As much varied material we can run through it the better!
Thanks for testing. I am pretty sure I have worked with you a number of times over the years. You are always one of the first to want to test something!
Josh
Old 04-29-2020, 04:54 PM
Josh
I noticed my tuning channels is much faster or am I imagining it ... I use OPENDCT but on some channels it would take a long time to load (no longer the case). I will get a h.265 file.
Old 04-29-2020, 05:07 PM
jvl711's Avatar
Do you know if you recording are in h.264? If so it is possible. If you look at the logs, does it appear that sage is detecting the format before starting playback. The JNI wrapper + the newer version of FFmpeg is much faster than the way sage is doing it. Sage is forking an old version of ffmpeg and then parsing the stdout.
My code seems to be detecting files in msecs, Where sage can on occasion take seconds to identify.
Sage is still doing Mpeg2/PS and TS files itself. Sage has its own format detection code for those codecs.
Old 04-29-2020, 05:09 PM
All my Comcast channels are in H264. Yes it appears that is the case.
Old 04-29-2020, 05:13 PM
jvl711's Avatar
Very interesting. That is a happy unintended bonus!
How much faster do you think it is?
Old 04-29-2020, 05:19 PM
A lot faster almost instantaneous .... I no longer get that annoying no data before tuning on some channels that were awful.
Wed 4/29 16:16:29.898 [AsyncWatch@c8e6c66] Doing pre-emptive file format detection on recording MediaFile....D:\SAGETEMP\The Carbonaro Effect Inside Carbonaro - S01E25 - A Problem With Chocolate Turtles and Seeds - 2489194-0.ts
Wed 4/29 16:16:29.898 [VideoFrame-444443564441@4d4e3c63] VF processing job null nPlayin=true
Wed 4/29 16:16:29.898 [VideoFrame-444443564441@4d4e3c63] isRec=false rd=157216 base=156218 eos=true
Wed 4/29 16:16:29.899 [VideoFrame-444443564441@4d4e3c63] VF thread is now waiting for 0:00:00.200
Wed 4/29 16:16:29.902 [AsyncWatch@c8e6c66] Using internal format detector first for: D:\SAGETEMP\The Carbonaro Effect Inside Carbonaro - S01E25 - A Problem With Chocolate Turtles and Seeds - 2489194-0.ts
Wed 4/29 16:16:29.903 [AsyncWatch@c8e6c66] AV Format:Ret:0 Program:1 Duration:1107a57 Format:AV-INF|f=MPEG2-TS;br=2884000;[bf=vid;f=H.264;fps=59.940060;fpsn=60000;fpsd=1001;ar=1.777778;arn=16;ard=9;w=1280;h=720;lace=0;main=yes;tag=0100;pid=256;index=0;];[bf=aud;f=AC3;sr=48000;ch=6;br=384000;main=yes;lang=eng;tag=0101;pid=257;index=1;];(0:0:01.785'711.1)
Wed 4/29 16:16:29.903 [AsyncWatch@c8e6c66] File Format Parsed-2a D:\SAGETEMP\The Carbonaro Effect Inside Carbonaro - S01E25 - A Problem With Chocolate Turtles and Seeds - 2489194-0.ts=MPEG2-TS 0:00:01 2884 kbps [#0 Video[H.264 59.94006 fps 1280x720 16:9 progressive id=0100]#1 Audio[AC3 48000 Hz 6 channels 384 kbps MAIN idx=1 id=0101 eng]]
Wed 4/29 16:16:29.903 [AsyncWatch@c8e6c66] File Format Parsed-2b D:\SAGETEMP\The Carbonaro Effect Inside Carbonaro - S01E25 - A Problem With Chocolate Turtles and Seeds - 2489194-0.ts=MPEG2-TS 0:00:01 2884 kbps [#0 Video[H.264 59.94006 fps 1280x720 16:9 progressive id=0100]#1 Audio[AC3 48000 Hz 6 channels 384 kbps MAIN idx=1 id=0101 eng]]
Wed 4/29 16:16:29.904 [AsyncWatch@c8e6c66] VF.submitJob(VFJob[WatchMF r=0.0 t=0 file=MediaFile[id=2931029 A[2489194,2486954,"The Carbonaro Effect: Inside Carbonaro",65717@0429.16:00,30,T] mask=TV host=NYPLAYERVIVO encodedBy=DCT-HDHomeRun Prime Tuner 13147C7B-2 on 127.0.0.1:9000 TRUTVHP format=MPEG2-TS 0:00:01 2884 kbps [#0 Video[H.264 59.94006 fps 1280x720 16:9 progressive id=0100]#1 Audio[AC3 48000 Hz 6 channels 384 kbps MAIN idx=1 id=0101 eng]] D:\SAGETEMP\The Carbonaro Effect Inside Carbonaro - S01E25 - A Problem With Chocolate Turtles and Seeds - 2489194-0.ts, Seg0[Wed 4/29 16:16:25.394-Wed 12/31 16:00:00.000]] ifn=null])
Old 04-29-2020, 05:26 PM
I believe this is a H265 file ....
Wed 4/29 16:22:46.755 [LibraryImporter@7e4ee54] Using internal format detector first for: \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg
Wed 4/29 16:22:46.770 [LibraryImporter@7e4ee54] AV Format:Ret:0 Program:1 Duration:751aa3400 Format:AV-INF|f=MPEG2-TS;br=384000;audioonly=1;[bf=aud;f=AC3;sr=48000;ch=2;br=384000;main=yes;lang=eng;tag=0100;pid=256;index=0;];(0:52:23.488'000.0)
Wed 4/29 16:22:46.771 [LibraryImporter@7e4ee54] File Format Parsed-2a \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg=MPEG2-TS 0:52:23 384 kbps [#0 Audio[AC3 48000 Hz 2 channels 384 kbps MAIN idx=0 id=0100 eng]]
Wed 4/29 16:22:46.771 [LibraryImporter@7e4ee54] File Format Parsed-2b \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg=MPEG2-TS 0:52:23 384 kbps [#0 Audio[AC3 48000 Hz 2 channels 384 kbps MAIN idx=0 id=0100 eng]]
Wed 4/29 16:22:46.772 [LibraryImporter@7e4ee54] Using external format detector because we only detected audio on the internal format...
Wed 4/29 16:22:46.772 [LibraryImporter@7e4ee54] Using the format detector plugin
Wed 4/29 16:22:46.772 [LibraryImporter@7e4ee54] MediaFormatParserPlugin processing: \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg
Wed 4/29 16:22:46.774 [LibraryImporter@7e4ee54] Find stream info called
0
Wed 4/29 16:22:46.784 [LibraryImporter@7e4ee54] MediaFormatParserPlugin processing complete: \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg
Wed 4/29 16:22:46.786 [LibraryImporter@7e4ee54] Added:MediaFile[id=2931031 A[2931034,2931032,"S08E02-Denial",0@0429.16:17,0,V] mask=V host=NYPLAYERVIVO encodedBy= format=MPEG2-TS -2562047788:00:54 893 kbps [#0 Audio[AC3 48000 Hz 2 channels 384 kbps idx=0 eng]#1 Video[HEVC 29.97003 fps 720x480 3:2 progressive]] \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg, Seg0[Wed 4/29 16:17:46.228-Wed 4/29 16:17:46.229]] num=1407
Wed 4/29 16:22:46.786 [LibraryImporter@7e4ee54] New Library File MediaFile[id=2931031 A[2931034,2931032,"S08E02-Denial",0@0429.16:17,0,V] mask=V host=NYPLAYERVIVO encodedBy= format=MPEG2-TS -2562047788:00:54 893 kbps [#0 Audio[AC3 48000 Hz 2 channels 384 kbps idx=0 eng]#1 Video[HEVC 29.97003 fps 720x480 3:2 progressive]] \\EDSYNOLOGY\Public\Playon\TVShows\Law & Order\Season 08\S08E02-Denial.mpg, Seg0[Wed 4/29 16:17:46.228-Wed 4/29 16:17:46.229]]
Old 04-29-2020, 05:27 PM
jvl711's Avatar
It does not appear that my plugin is involved in that portion of the log. It is using the internal format detector, which is completely sage code. Is there anything before or after in the log where it says it is using the plugin? Maybe it is just a coincidence it is faster.
Old 04-29-2020, 05:34 PM
H265 file did not play on HD300 sound no picture but played fine on my FireTV mini Client.
Old 04-29-2020, 05:45 PM
KryptoNyte's Avatar
H265 file did not play on HD300 ...
I was thinking that h.265 on an HD300 would never be possible due to the hardware limitations. Is that correct?
Old 04-29-2020, 05:47 PM
jvl711's Avatar
That is correct, but sage could in theory be programmed to transcode. Especially since it now knows what the files are.
Commercial Detector Plugin Disabled LJSSageUser Phoenix 5 03-09-2014 05:34 PM
Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) cslatt SageTV Customizations 48 06-11-2012 10:44 AM
Plugin request for SageTV Windows Client: Autofrequency plugin mkanet SageTV v7 Customizations 3 11-12-2011 09:33 AM
Do I have to format my WHS to use SageTV? blackcows General Discussion 9 10-13-2009 06:51 PM
IR Code (Pronto Format) as in UIRT Helper --> SageTV Format as in Sagetv.properties krasev Hardware Support 0 09-12-2006 10:56 PM
