Old 12-16-2020, 03:48 PM
jvl711's Avatar
jvl711 jvl711 is offline
Smile SageTVTranscoder Plugin
This plugin is an updated version of the "CORE" SageTVTranscoder.exe that comes with SageTV. This version is based off of FFmpeg version 4.3.1. The project is being maintained as a fork to the FFmpeg project, so hopefully it will make it easier to upgrade to future versions.
Known Issues:
  1. Some of the built in transcoding profiles in SageTV use deprecated/removed command line arguments. You will need to add your own custom profiles at this time for the transcoding profiles that are not working.
Transcoding Profiles:
Some transcoding profiles that nyplayer posted. These will copy all audio and subtitles but transcode the video. The slower the encode the better the quality. You will need to shutdown SageTV server, and add these to the sage properties file.
transcoder/formats/MKV-H264\superfast\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset superfast -c:v libx264;]
transcoder/formats/MKV-H264\veryfast\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset veryfast -c:v libx264;]
transcoder/formats/MKV-H264\faster\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset faster -c:v libx264;]
transcoder/formats/MKV-H264\fast\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset fast -c:v libx264;]
transcoder/formats/MKV-H264\Medium\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset medium -c:v libx264;]
transcoder/formats/MKV-H264\slow\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset slow -c:v libx264;]
transcoder/formats/MKV-H264\slower\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset slower -c:v libx264;]
transcoder/formats/MKV-H264\veryslow\ MKV=f\=matroska;MCompressionDetails\=-c copy -preset veryslow -c:v libx264;]
transcoder/formats/MKV-Remux\ MKV=f\=matroska;MCompressionDetails\=-c copy;]
FAQ:
Q: What does the SageTVTranscoder do in SageTV?
A: It is responsible for a number of different tasks:
  1. Realtime transcoding of video files that are either in an unsupported format, or because of bandwidth limitations
  2. Thumbnail generation of media files. This is how SageTV creates the thumbnail image for recordings
  3. Conversion of recordings/library content to different formats
  4. Media format detection for formats that require the external format detector. I believe that is every except for .ts/.ps, and mp3 files.
Q: Why should I care about this? Seems like this does the same thing as the original SageTVTranscoder.exe?
A: Good question, there are a number of enhancements from using the newer version of FFmpeg:
  1. Support for transcoding and encoding into h265 and other newere codecs
  2. Support for identifying newer codecs and containers
  3. Potential performance increases in all the areas SageTV utilizes the SageTVTranscoder
  4. Stability improvements because of years of bugfixes and enhancements made by the FFmpeg team
Q: How do I install this?
A: It is available under as a SageTV plugin under General. It is called SageTVTranscoder (FFmpeg) Windows x64/x32. Pick the version that is appropriate to your system.
Q: What do I do if I find an issue/bug, or have an enhancement request?
A: You are free to bring up, or discuss any issues/bugs or potential enhancements here, but I would like it if you would please enter an issue into the github repo for tracking purposes. You can do that here under issues: https://github.com/jvl711/SageTVTranscoder-FFmpeg
Q: Can I contribute to this project?
A: Why yes you can! The project is a fork of FFmpeg, and is written in C. I could use help maintaining this, and there is definitely some code I do not understand and could use assistance with. You can fork the repo and submit pull requests. You can reach out to me on the forums, patreon or github. If you are not a programmer I am sure you could help with guides and general support.
Github Link: https://github.com/jvl711/SageTVTranscoder-FFmpeg
Versions:
v1.0.0 - Initial feature complete (Beta) release
v1.0.1 - Added x32 windows build
v1.0.2 - Fixed an issue with thumbnail generation on client machine. "stv://127.0.0.1/" translated to locally accessible path.
v1.0.3 - Fixed an issue with live tv transcoding and transitioning to a new program.
v1.0.4 - Added libx265 support
Projects I am currently maintaining
SageTV Andoid Client
Media Format Parser Plugin
JavaFFmpegLibrary
SageTVTranscoder
If you like the work I am doing and would like to support it you can become a Patreon member.
Old 12-17-2020, 11:25 AM
A question regarding thumbnail generation - I believe that the thumbnail is created at an interval of something like 30 seconds after the start of the recording. Is that the case? And can this thumbnail time offset be changed by the user? In an ideal world it would be good to have the offset time be confifurable based on Show Title, just like the custom skip times plugin. For example, for sporting events you may want the thumbnail to be at 900 seconds into the recording.
Old 12-17-2020, 12:43 PM
jvl711's Avatar
Hi Wayner,
It will behave the way that SageTV does currently with thumbnail generation. I think there is a setting that you can choose the time for how far by default into a show the thumbnail is created. Any option you can configure in SageTV today should be supported...
This is attempting to be a one to one replacement of the current SageTVTranscoder, so all current functions "should" work the same.
I think it may makes sense to add something like this to the core SageTV to possibly allow the configuration on a favorite. I will tell you in my own system, that I do not even use the ones that come from SageTV. I actually pull them down from TMDB. They seem to be picked by the user base, and are a much better representation of the show.
Josh
JavaFFmpegLibrary
SageTVTranscoder
Old 12-17-2020, 02:33 PM
I still get bad audio when testing to always transcode locally on all my devices ... It cracks and is distorted.... also when watching Comcast H264 with transcoding get no video.
Maybe somebody that has a FireTV can also test this.... see if they too suffer from distorted audio.
Old 12-17-2020, 05:07 PM
jvl711's Avatar
I just ran thru this on my server, and it seems to be working fine. Can you confirm that you have the right version of the Sage.jar. The HD fixed transcoding will only work with my patched jar file.
From reviewing the logs you sent me, it looked like SageTV was not passing the correct options.
Josh
JavaFFmpegLibrary
SageTVTranscoder
Old 12-18-2020, 08:39 AM
Josh
I think that might be it I rebuilt it and did not get your Sage.jar maybe you should post your jar on the first page. There is no mention about the new jar.
Edit that was it ... maybe update your instructions that a new jar is needed and post where it can be downloaded.
Old 12-18-2020, 01:52 PM
jvl711's Avatar
I added a note and a link to the top of the Android Client post with a direct link to the file. I was holding on to seeing if we could get another SageTV release until I made a decision on if I am going to add the stream copy changes.
JavaFFmpegLibrary
SageTVTranscoder
Old 12-18-2020, 04:54 PM
Ok thanks ... great work
Old 12-18-2020, 05:30 PM
KryptoNyte's Avatar
This is fantastic!
I just connected a Firestick 4k over my phone's hotspot as a remote connection test (fixed, 3 mbps), then thrashed a recording FF, REW, auto compskip. After moving back and forth, no more odd green pixelated screens, the video/audio picks up quickly when replay starts - this is really great work.
Thank you!
Oh, and the installation of the plugin ... painless.
Old 12-21-2020, 01:03 PM
jvl711's Avatar
Originally Posted by KryptoNyte View Post
This is fantastic!
Thank you!
Thank you for the feedback. That is good to hear!
JavaFFmpegLibrary
SageTVTranscoder
Old 12-21-2020, 01:05 PM
jvl711's Avatar
Hi All,
Just wanted to let you guys know that windows 32 bit build is coming soon. I was able to get it to build, and I have updated my build scripts. I hope to release at some point this week, time allowing.
Josh
JavaFFmpegLibrary
SageTVTranscoder
Old 12-21-2020, 03:50 PM
Hi All,
Josh
Thanks it has been rock solid thanks for your work you have put in to keep sagetv going.
Old 12-21-2020, 04:36 PM
AlphaCrew AlphaCrew is offline
So this only applies to the android app, and not the PC client/server?
Old 12-21-2020, 06:38 PM
Telecore's Avatar
Telecore Telecore is offline
First of all - jvl711 thanks for all of your efforts - I found a potential problem that I want to relay after I changed out the jar file and installed the plugin; unfortunately I don't recall all the details (and I have since uninstalled), but I am certain my HEVC-10 encoded MKV files with DTS soundtracks would not play and an error message appeared indicating that there was an audio error. This happened both on FireTV 4K and the Nvidia Shield. What I am not certain about is whether the HEVC-10 MKVs with AC-3 soundtracks worked or not. Both DTS and AC-3 work with the old jar and without the plugin on android clients. Anyways wanted to let everyone know and see if someone else encountered the same problem. I only have the 1 system so I had to restore it to make sure everything is working for my family.
SageTV-V9(64bit): Win10/i3-4370/OpenDCT/HDHR-Quatro (OTA)
AndroidTV+Miniclient: Nvidia Shield(x3)/FireTV-4K(x8)
Channels-DVR:Win10/i3-4340/HDHR Quatro 4K/TVE(YTTV)
Old 12-22-2020, 06:44 AM
jvl711's Avatar
This applies to all of SageTV. See Q AND A on first post.
Josh
JavaFFmpegLibrary
SageTVTranscoder
Old 12-22-2020, 06:49 AM
jvl711's Avatar
Hi Telecore,
What were you attempting to do? Where you applying fixed transcoding? Why did you add the new Sage.jar. Where you expecting to test a feature? Can you post the SageTVTranscoder.log file.
H265 should not need to be transcoded on the Firestick 4k. It should just playback. So transcoding should not be involved unless this is a low bandwidth, or you forced transcoding with always encode.
Josh
JavaFFmpegLibrary
SageTVTranscoder
Old 12-22-2020, 03:01 PM
Telecore's Avatar
Not testing transcoding - just (1) regression testing to see if anything got broke and (2) trying to see what could be gained (outside of transcoding) from your list of enhancements (I was hoping to make SageTV more aware of HEVC content); in any event wanted to let you know that something broke in a non-transcoding use case
Old 12-23-2020, 09:16 AM
jvl711's Avatar
Thanks Telecore.
Let me know if you have a chance to look into this more. I am not able to repro on my side. I would need some logs from you to look into it closer. It is possible it is detecting something a little differently on your side that Sage is not liking.
Josh
JavaFFmpegLibrary
SageTVTranscoder
Old 12-23-2020, 11:56 AM
Josh
So I installed the PI (Server), rebooted machine and tried to convert a video to H264 MKV and as it always has, it failed.
I don't see any difference in the SageTV client as it pertains to transcoding or it's options.
Does the PI need to be installed in the client as well?
Old 12-23-2020, 03:13 PM
I also tried to transcode a recording to mkv in Windows server and it failed I think new profiles will have to be added.
SageTVTranscoder.exe from 6.5.14 Stuntman SageTV Beta Test Software 2 05-13-2009 08:17 AM
What does SageTVtranscoder.exe do? autoboy SageTV Software 5 04-23-2008 01:55 PM
sagetvtranscoder.exe always at 50% showson1 SageTV Software 3 03-30-2008 01:46 AM
SageTVTranscoder.exe jgsouthard SageTV Beta Test Software 40 11-03-2007 01:13 PM
SageTvTranscoder.exe ?? mike_15 SageTV Software 4 10-21-2007 09:42 PM
